Question about Alpine INE-W940 6.1-Inch Audio/Video/Navigation Receiver
How do you audio settings - Alpine INE-W940 6.1-Inch Audio/Video/Navigation Receiver
How do I disable audio description on an LG 55LF6000 TV?
Go to set up or settings and find audio options, then deselect audio description.
Aug 06, 2016 | LG Televison & Video
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
How come on my Elgato Game capture HD for mac i can never get audio comming through my computer on any system
1) Make sure your game console is set to output audio via the cables you are using.
Solution: The PlayStation 3 (PS3), Xbox 360, and other game consoles have various options for audio output. Make sure you have selected the right audio output option for Elgato Game Capture HD to use.
When using the PS3 with Elgato Game Capture HD, make sure you set the Audio Output settings to Audio Input Connector / SCART / AV MULTI
You can refer to this article for more details:
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
When using the Xbox 360, you can refer to this article:
http://support.xbox.com/en-US/xbox-360/audio-video-setup-and-use/configure-audio-settings
For an HDMI connection with your Xbox 360, try these settings:
1) Start the Xbox 360 console without a disc in the disc tray.
2) Go to Settings and select System.
3) Select Console Settings, and then select Audio.
4) Select Digital Output, and then select Digital Stereo My Elgato Game Capture HD doesn
Jun 21, 2014 | EyeTV Elgato Game Capture HD High...
When i install application or games on my sony ericsson aino it display operation failed, how can i fix this?
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 4410
Jul 10, 2013 | Audio Players & Recorders
3250hd
How have you connected the audio cables to the TV? The 3250HD has component, DVI, and composite video out. There is also two analog audio outputs (for the component and composite video) and a digital audio output. Make sure that you are using a TV and not a monitor. Many monitors do not have built-in speakers. (In that case, use external speakers.)
If you use the digital audio output, make sure that your audio receiver audio input is connected to the set top box audio out. Then make sure to set the correct source for that audio signal. (Note the TV may have a digital audio port; that is an audio out.)
If you are using one of the analog audio outputs directly to the TV, make sure that you are using the correct set of audio IN on the TV and audio out on the set top box. (If you are on the Component input, your audio won't be heard if you are using the Composite audio output.)
Next try different audio cables. Make sure that the TV speakers are on. (Some TVs have an option to disable the speakers if you use external speakers at times.) Try connecting the audio output to a receiver and speaker system (or speakers with aux in). You might need an RCA F/F to 3.5 mm M adapter for some devices. If another set of speakers do not work, then the set-top box probably has a broken audio output. If another set of speakers work, then the problem is with the TV audio. This could be a problem with the jack or the speakers.
I hope this helps.
May 02, 2013 | Black Box Computers & Internet
Iv been on skyp we can see each other but there is no sound can you help many thank
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
May 01, 2011 | Acer (54.AA806.001) Sound Card
I am using Skype My voice is not going.,I have checked headset ,headset is ok.........now aht to do ?
Apr 21, 2011 | Computers & Internet
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
I have the toshiba 42hl167 and the volume is not working. only works with play station. cant here cable or bose system.
I would reset the factory defaults on the TV, but some complicating information follows these instructions:
Reset Factory Defaults
To reset all settings and channels to their factory
default values:
1 Press Y and open the Setup menu.
2 Highlight Installation and press T. A new set of
Installation menu icons will appear.
3 Open the System Status menu, highlight System
Information, and press T.
4 Press C c to scroll through the menu bar to select
Factory Defaults.
5 Enter your PIN code (or 0000 if no PIN code has been set).
Because the PC and HDMI-1 inputs share the same set of analog audio inputs, the PC Audio menu setting influences the HDMI 1 Audio menu setting. If PC Audio is set to “No,” the HDMI 1 Audio setting changes to “Auto.” If PC Audio is set to “Yes,” the HDMI 1 Audio setting is set to “Digital” and is grayed out in the menu. (Also see item 5 on page 12 of manual and “Setting the HDMI™ Audio mode” on page 43 of manual).
There is also some good information on pp.20-22 and 54-57 of the manual - this one has a lot of audio hookups and settings.
-Tha Mp3 Doctor
Dec 17, 2008 | Toshiba 42HL167 42 in. LCD Television
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Alpine INE-W940 6.1-Inch Audio/Video/Navigation Receiver Logo
18 people viewed this question
Top Alpine Televison & Video Experts
Vernon Taylor
ray gallant
Are you an Alpine Televison and Video Expert? Answer questions, earn points and help others
