Question about Goodyear 1979 Mercedes-Benz 300SD Accessory Drive Belt
HOW DO YOU ACCESS THE FUEL LEVEL SENSOR UNIT ON A 1986SDL MERCEDES WITH A POWER REAR SEAT CUSHION.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Drop the fuel tank
Posted on Dec 30, 2013
How to remove the fuel tank of mercedes 1994 c230 and fix the fuel gauge please tell me , its showing empty the tank but full of petrol, i want to remove the gauge and change or clean it.
The official repair time for replacing the fuel tank is almost seven hours but the given time for replacing the fuel level sensor is less than two hours so it would seem it is not necessary to remove the fuel tank, though it could be necessary to lower it a little.
I suggest you obtain model-specific repair information for your model. There might be access through the body after removing the rear seat cushion, for instance.
Feb 17, 2015 | 1994 Mercedes-Benz C-Class
Please help. 1994 Mercedes E320 power windows are dead.
Under the rear seat cushion on the drivers side is a control module/ relay box that operates all the windows and the sunroof for the car. To lift up the rear seat cushion there is a tab on both sides of the rear seat that you push on while lifting the seat up. Once the seat cushion is out you can find the relay housing on the driver side right near the bend. Start there since everything went out all at once. Wrecking yard is the best place to pick up another one.
Jul 19, 2012 | 1994 Mercedes-Benz E-Class
Replace fuel pump 1993 mazda 323
REMOVAL & INSTALLATION
323, Protege, 520-22 626 and MX-6 and 522-24 MX-3 Models
See Figures 1 and 2
  1. Relieve the fuel pressure and disconnect the negative battery cable.
  2. If not already removed, depress the clips on each end of the rear seat cushion and remove the cushion.
Fig. Fig. 1: Detach the fuel hoses and electrical connections from the fuel pump, then remove the attaching screws and the pump
Fig. Fig. 2: Exploded view of the fuel pump assembly for the 323, Protege, 520-22 626, MX-6 and 522-24 MX-3
  1. If not already done, detach the electrical connector from the fuel pump/sending unit.
  2. Remove the attaching screws from the fuel pump/sending unit access cover and remove the cover.
  3. Disconnect the fuel supply and return hoses from the fuel pump/sending unit.
  4. Remove the attaching screws and the fuel pump/sending unit from the fuel tank.
  5. Detach the sending unit electrical connector, remove the sending unit attaching nuts and remove the sending unit from the fuel pump assembly.
To install:
  1. Attach the sending unit to the fuel pump assembly and install the nuts. attach the sending unit electrical connector.
  2. Install the fuel pump/sending unit into the fuel tank with a new gasket and install the mounting screws.
  3. Connect the fuel supply and return lines.
  4. Install the access cover and the mounting screws.
  5. Attach the sending unit electrical connector.
  6. Position the rear seat cushion over the floor, making sure to align the retaining pins with the clips. Push down firmly until the two retaining pins are locked into the rear seat retaining clips.
  7. Connect the negative battery cable, start the engine and check for proper system operation and for fuel leaks.
May 08, 2012 | 1993 Mazda 323
Cant find fuel filter on mercedes w211
The fuel filter is part of the fuel sending units inside the fuel tank. There is no external fuel filter on the W211. The fuel sending units are located under the rear seat cushion behind the access panels.
Feb 18, 2012 | 2002 Mercedes-Benz E-Class
Mercedes c 240 2001 turns over but will not crrank , 3/4 tank of gas
Hi there, it sounds like the fuel pumps have gone bad, they can be replaced by removing rear seat bottom cushion and removing metal cover and can be accesses on passenger side!
happy motoring!!
Mar 01, 2010 | 2001 Mercedes-Benz C-Class
How replace the rear shocks on mercedes 420 sel
You will need to remove the rear seats to access the hole just above the shock. Remove the bottom seat cushion first, then find the small bolts that hold the upper seat to the frame. Once removed, you will see access to the top of the shocks (might have a plastic covering the hole).
Feb 14, 2010 | 1991 Mercedes-Benz 420
How do you change fuel pump on a 04 dodge intrepid?
hope this helps...
Pump Module—Left Side
  1. Release the fuel pressure.
  2. Disconnect negative battery cable.
    NOTE The fuel level of the vehicle must be below 5/8 of a tank before you remove the module lock-rings. If it is above that you can spill fuel in the vehicle.
  3. Drain partial fuel from fuel tank through the filler tube. Use a hard nylon tube, with a 30° cut on the end, to push the check valve open to drain fuel from tank.
  4. Remove the rear lower seat cushion.
  5. Push seat back and up to remove seat cushion.
  6. Fold back the foam pad covering access cover for modules.
  7. Disconnect the electrical connector from left side module.
  8. Mark the module orientation.
  9. Use special tool 9340 to remove left side module lock ring.
  10. Drain fuel from left side of fuel tank. Lift module up enough to push hose into tank and drain. Do not spill fuel in interior of vehicle.
  11. Disconnect the electrical connector for the left side fuel level card from bottom of the module top.
  12. Disconnect the electrical connector for the right side fuel level sending card.
  13. Lift module top half off and tip lower half on its side to drain remaining fuel from the reservoir.
  14. Remove wire from module.
  15. Use a screwdriver to separate the locking tabs on the level sending card.
  16. Lift level sending card straight up and out of module.
  17. Disconnect the electrical wiring from module.
  18. Remove level sending card.
To install:
  1. Install level sending card, make sure that the locking tabs are locked on the card.
  2. Route wires in the proper location.
  3. Install module top to module bottom.
  4. Connect the electrical connectors for right side fuel level sending card, left side module card and fuel pump.
  5. Install module and align marks on the module for proper orientation.
  6. Install module lock-ring.
  7. Use special tool #9340 to tighten left side module lock ring.
  8. Connect the electrical connector to left side module and install plastic access cover.
  9. Fold the foam pad covering access cover for modules back into place.
  10. Install rear lower seat cushion
  11. Rear lower seat cushion installed.
  12. Fill fuel tank.
  13. Connect negative battery cable.
  14. Fill fuel tank. Use the scan tool to pressurize the fuel system. Check for
Jan 28, 2010 | 2004 Dodge Intrepid
How to change fuel pump on 2005 nissan sentra 1.8L
1. Release fuel pressure by removing the fuel pump fuse and spinning the engine over.
2. Disconnect the battery ground cable.
3. Open the fuel filler lid and remove the fuel filler cap at relieve the pressure in the fuel tank.
4. Remove the rear seat cushion.
5. Remove the inspection hole cover located under the rear seat cushion by rotating the attaching clips 90 degrees to line them up for removal.
6. Disconnect the fuel pump assembly electrical connector.
7. Disconnect the fuel feed hose quick connector. You will need to push in the winged tabs at the end of the fuel line. Be careful not to break it.
8. Remove the six fuel level sensor and fuel pump assembly retainer ring screws.
9. To remove, pull up the fuel pump assembly. Be careful not to damage the fuel level sensor. You will have to tilt the assembly to remove it completely.
Dec 19, 2009 | 2005 Nissan Sentra
How do i replace the fuel pump in my 1993 mazda 626 2.5
3. If not already done, detach the electrical connector from the fuel pump/sending unit.
4. Remove the attaching screws from the fuel pump/sending unit access cover and remove the cover.
5. Disconnect the fuel supply and return hoses from the fuel pump/sending unit.
6. Remove the attaching screws and the fuel pump/sending unit from the fuel tank.
7. Detach the sending unit electrical connector, remove the sending unit attaching nuts and remove the sending unit from the fuel pump assembly.
To install:
Jun 13, 2009 | 1993 Mazda 626
I am not getting fuel to my engine
Removal
  1. Relieve the Fuel System Pressure . Refer to the procedure in this section.
Cushion Cover and Pad, Rear Seat — One-Piece and 50/50 Split Fold Removal
  1. Remove the two rear seat cushion bolts.
  1. Fold the rear seat back cover and cushion (60084) forward.
  1. Carefully pull the rear seat cushion and cover (60030) out from under the rear seat back cover and cushion and remove the rear seat cushion and cover from the vehicle
  1. Remove the rear seat cushion and cover (60030). Refer to Section 01-10 for the removal procedure.
  1. Remove the three luggage compartment floor cover hold-down pins and fold the luggage compartment floor cover (45455) forward until the fuel pump assembly access plate is visible.
  1. Remove the four fuel pump assembly access plate screws, the ground lead, and the fuel pump assembly access plate from the chassis.
  1. Disconnect the fuel pump assembly electrical connector.
  1. On 4-door vehicles, remove the fuel vapor tube shutoff valve bolt and the evaporative emission tube shut off valve (9G332) from the bracket on the fuel pump assembly housing.
  1. Loosen the two hose clamps and disconnect the two fuel pump hoses from the fuel pump hose fittings on the fuel pump assembly housing.
  1. Remove the four screws (2-door) or eight screws (4-door) and lift the fuel pump assembly housing from the fuel tank (9002).
  1. Disconnect the fuel level sensor electrical connector.
  1. Remove the two fuel level sensor washers and fuel level sensor nuts and the fuel level sensor.
Section 10-01: Fuel Tank, Filters, Lines and Electric Fuel Pump 1996 Aspire Workshop Manual
REMOVAL AND INSTALLATION Fuel Pump Removal
  1. Remove the fuel level sensor. Refer to the Fuel Level Sensor removal procedure in this section.
  1. Remove the fuel pump screw, fuel pump grommet and the fuel pump bracket from the bottom of the fuel pump (9350).
  1. Remove the fuel tank sender filter bracket, fuel tank sender filter (9A011) and the fuel tank sender filter retainer from the fuel pump.
  1. Disconnect the fuel pump electrical connector.
  1. Remove the clamp and the fuel pump from the fuel pump assembly housing.
Apr 19, 2009 | 1995 Ford Aspire
Goodyear 1979 Mercedes-Benz 300SD Accessory Drive Belt Logo
26 people viewed this question
Top Goodyear Air Tools & Compressors Experts
old fart58
Mike
Are you a Goodyear Air Tool and Compressor Expert? Answer questions, earn points and help others
