Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman lawn mower 17.5hp won/t start
When you choke it bacfires
  • 323 Answers
That's a good indication the air/fuel mixture is off. Before you try to adjust the carb, make sure the air filter and prefilter are clean. If they are filthy, replace them. Make sure the carb looks clean when you take the air filter off.
Adjustments to the carb are not easy and if you don't have a service manual or operators manual it's probably something you don't want to tackle, unless you have a good working knowledge of small engine carbs.
I would probably have that serviced. But first, I couldn't resist taking the air cleaner off, turning the throttle up about half way, and squirting a small amount of starter fluid into the carb, then crank it to see if it starts.
Do not choke it. If it starts, run it a while, but put a clean air filter and prefilter on it while it is running. Then see how it runs, and if it seems okay, try cutting a little with it.
Have you checked the plug(s) lately? Sometimes lots of things combined will cause one small problem. I didn't mean to write a book here. If you do all these things and it runs okay now, and after you finish you change plug(s), and when it gets cold again (next day) try and start it again with the choke. Make sure the throttle is moved up about 2/3 of the way.
If you run into the same backfiring problem, it's time to take it in to see the doc. Probably air/fuel misture is off, and that's why it backfires when you choke it. Good luck!
Sirwriter
Posted on May 18, 2009
I have a craftsman LT 2000 22 horse, the engine sounds like it's struggling and bacfires?
Probably a fuel issue. Backfiring is usually a timing or fuel issue. One can cause the other. As this is an engine issue, please post model and type.
Jul 06, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Where is primer on craftsman platinum push mower
It may not have one. Some mowers auto choke using spring tension on the choke plate in the carb. They open the choke when the engine speeds up after starting.
Apr 23, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Where is the choke
Many Briggs engine have a primer rather than a choke, the 675 series has a choke that is worked by an air vain, the choke is always closed when the engine is stopped, once the engine starts air pressure from the flywheel pushes the air vain which in turn opens the choke to allow the engine to run normally, there is also a version with a bi thermal switch on the back of the muffler, as the muffler heats up the switch opens the choke.
Feb 12, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
388 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
