Question about Hawking Computers & Internet
Smart repeater pro will not connect to internet
During setup states it has an internet connection, however will not connect when I try to go to a web page.
etaf
  • 779 Answers
SOURCE: Repeater cuts out
I would suggest a few things 1) see if a firmware update for the device 2) It may be a DNS issue can you post the model what status are the lights on the repeater next do an IPCONFIG /ALL - see later and some ping tests to see if its a DNS ISSUE ipconfig /all TWO Methods to do that - some people have problems with ONE---- ONE --------------------------------- start run cmd ipconfig /all rightclick in the box select all enter control key + C key - to copy then reply here and control key + V to paste TWO ----------------------------------------------- Start, Run, CMD to open a DOS window and type: IPCONFIG /ALL >C:\RESULT.TXT Open C:\RESULT.TXT with Notepad and copy/paste the entire results here. NEXT lets see if you can get out onto the internet with both names and IP's - its possible the IP number you get back on the first test is different to the one I post {I'm in UK} so use the number you get instead of mine ------------------------------------------------ try ping the name and then the IP see below start run cmd C:\Documents and Settings\wayne>[b]ping {the default gateway ipaddress you got above }[/b] C:\Documents and Settings\wayne>[b]ping google.com[/b][quote] Pinging google.com [64.233.187.99] with 32 bytes of data: Reply from 64.233.187.99: bytes=32 time=120ms TTL=243 Reply from 64.233.187.99: bytes=32 time=107ms TTL=243 Reply from 64.233.187.99: bytes=32 time=102ms TTL=243 Reply from 64.233.187.99: bytes=32 time=101ms TTL=243 Ping statistics for 64.233.187.99: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 101ms, Maximum = 120ms, Average = 107ms C:\Documents and Settings\wayne>ping 64.233.187.991 Ping request could not find host 64.233.187.991. Please check the name and try a gain. [/quote] C:\Documents and Settings\wayne>[b]ping 64.233.187.99[/b][quote] Pinging 64.233.187.99 with 32 bytes of data: Reply from 64.233.187.99: bytes=32 time=116ms TTL=243 Reply from 64.233.187.99: bytes=32 time=113ms TTL=243 Reply from 64.233.187.99: bytes=32 time=113ms TTL=243 Reply from 64.233.187.99: bytes=32 time=111ms TTL=243 Ping statistics for 64.233.187.99: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 111ms, Maximum = 116ms, Average = 113ms C:\Documents and Settings\wayne>[/quote]
Posted on Apr 12, 2007
SOURCE: Internet Explorer cannot display the web page
I am having this issue. One laptop works the other not so much. I cant use IE. I can use and run AIM and Windows Messenger. CANNOT do anything else. Did all the ip renew release and all that ****. cant figure it out... Have an excelent conection but IE wont do its thing... Hapigm_29@hotmail.com
Posted on May 08, 2008
Benimur
  • 6966 Answers
SOURCE: Wireless repeater
Might it be that your problem exist because both the 2Wire HW1700 wireless modem and the D-Link DWL-G710 have their DHCP features enabled? During the setup, use static IP adds, disable the DHCP function of the HW1700, follow setup instruction/procedures of the DWL-G710.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 19, 2008
mastersaintx
  • 928 Answers
SOURCE: Router cannot connect on internet at setup wizard
Hi pag Smartbro ang gamit mo hindi mo pwede gamiting ang setup wizard. Iba kasi ang paraan ng connection sa SMartBro. Mahirap explain it would be best if you call Linksys Philippine support since there are so many ways to connect Smartbro to a Linksys router. The number is 1-800-1-114-1695 toll free. or kung gusto mo sa Yahoo ID ko nalang mastersaintx message mo ko sa umaga.
Posted on Sep 03, 2008
  • 5 Answers
SOURCE: Can not connect to internet when WJ enabled (Ultrasurf plugin)
WJ Enabled is UltraSurf.... just don't use UltraSurf for firefox. Go to Tools>>Add-ons>>UltraSurft Firefox Tool and select Disable or Uninstall...
Then use a web-based proxy.
Posted on Apr 28, 2009
My TV will connect to the network but is not connected to the internet.
Check the videos to understand how set up the network connection on sharp tv . Hope it would help you to set up your tv. If you go for manual connection the you have to have some information . you can get those information from your internet provider comcast.
http://electro-medical.blogspot.com/
Easy Sharp Aquos TV Setup wifi internet network connection for Netflix apps
Wireless setup for Sharp AQUOS TVs HSN How Setup WiFi On The Sharp Aquos 60 Smart TV
Nov 13, 2015 | Sharp Aquos Televison & Video
Can my Samsung 46" LED TV connect to the internet
If you have purchased a Samsung smart TV with Smart Hub you will be able to connect to the internet using the web browser found in the Apps when running Smart Hub function.
You will need to have either an Ethernet cable connected to your TV from your router or you can connect using WiFi is your TV is so equipped.
You need to use the menu to go to the internet connection setup.
I hope this answer is helpful to you.
Mar 01, 2015 | Samsung Televison & Video
Hawking smart repeater pro
I CAN FIX THIS WITH A REMOTE CONNECTION...call 225-290-5733
Dec 26, 2013 | Hawking Hi-Gain Wireless-300N Smart...
How do i find/access product embedded web server page IPv4 address 192.168.1.102
Hello Eli Tschetter,
Type in the Printter's IP in the Address bar of Internet explorer ( or any browser ) to access the Embedded Web Server of the printer.
Oct 27, 2012 | HewlettPackard LaserJet Pro 1102w Printer
Hawking HW2R1 repeater doesn't get internet
first of all bring the repeater closer to your router (after upgrade you can return it to its original location)
Mar 25, 2017 | Hawking HW2R1 Dual Radio Smart Repeater
My WNA3100 USB wireless adapter connects to the Internet via the NETGEAR Smart software. However, the computer is not reading it as an active wireless connection. Instead, the NETGEAR software says I'm...
I Would guess, that windows is leaving the handeling of the wireless connection to the NETGEAR software, and therefor not registering the device ad connected.
To make Windows regain controle take a look at this: http://www.bukisa.com/articles/115878_how-to-let-windows-configure-your-wireless-network-connection-in-xp
Mar 13, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
HI I have a HP officejet pro 7680 and a sony vaio laptop. I am trying to connect wireless but it says during install that it can not find the printer. We also have 4 other laptops that are connected to...
during install it should give you a option for manual get the ip number from the printer and add the ip manually ( press setup and go to networking on the printer) if that does not work then it is your security on the laptop blocking the printer being detected I suggest turn off all your security and then try
Jan 26, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP Photosmart D7460 Error Message
Remove the HP Smartweb printing software.
1. In the Start menu select All Programs > HP Smart Web Printing > Uninstall HP Smart Web Printing.
2. Follow the onscreen prompts.
You can also open the 'Control Panel' from the 'Start menu' and open 'Add or Remove' Programs. Select 'HP Smart Web Printing' in the 'Add or Remove' Programs window, and then click 'Remove'.
If the changes you make in the Page Setup dialog of Internet Explorer are not reflected in the Page Setup dialog of the Print Clips window and vice versa ?
This is a known problem, and not unique to HP Smart Web Printing. When printing from the Internet Explorer File menu, select File > Page Setup and make your settings there. When printing from the Print Clips window, click the Page Setup button and make your settings there.
Now install the smart web printing software from the weblink provided below:
After removing the smart web printing software, please visit the weblink and download the HP Smart Web Printing 4.05 software from the webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=dj-56929-5&cc=us&lc=en&dlc=en
Just copy and paste the entire link(without spaces) in the web browser and press enter.
For more information on how to install the software visit the below weblink which leads to a webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c00793678
After performing the steps mentioned above, check the functionality.
Oct 27, 2008 | HP Photosmart D7460 Printer
Local Only
The problem might be that you have good connection to the router but having connection trouble between your router and the internet.
Try accessing your router by typing your Gateway into the address field of the web browser of your choice.
Then click on WAN (Wide Area Network) and check your external IP Address. Beside it you will find a button that says "Renew".
The loss of connection might be the result of poor router configuration, bad cable connection or ISP (Internet Service Provider) connectivity trouble.
May 27, 2008 | Hawking HWREG1 Repeater
Open Questions:
Computers & Internet Logo
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
