Question about Toshiba 32A41 32" TV
Replacement of connection for the cable
How would I replace the connection for the cable (anntena) on my 32 inch toshiba standard television
  • 593 Answers
If you remove the back of the TV (be very careful of the flyback transformer as it can kill you! its the little lead that goes straight to the back of the tube) and look at the old connector. It is called an F81 barrel connector and the old one is probably just soldered in, you can get another one at radio shack or flag down a CATV guy and just ask him for one and solder it in inplace of the old one. Or just use the RCA inputs.
Posted on Mar 03, 2008
My Toshiba 32 inch combination TV will not power on model # 32 HLX 95
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jul 21, 2015 | Toshiba Televison & Video
Ypbpr not working on toshiba 32 inch
If all other inputs are working and only component video is not, the input selector IC has damaged and should be replaced.
Apr 29, 2012 | Toshiba Televison & Video
32 inch toshiba tv plays awhile then goes off and wont come back
It is very possible that you have solder joints on the main board that need to be re-soldered.
Dec 29, 2009 | Toshiba 32A33 32" TV
We have a great picture on our Toshiba TV, but no sound!
recheck all the cables connections,and might replace all the cables,if not solve ur spechker
have cold soldier connections joints or short or
dead all together in ur tv.
Aug 13, 2009 | Toshiba 32D46 32" TV
Red light blinking no picture no sound
tart checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
May 22, 2009 | Toshiba 32A43 32" TV
Toshiba television
it can be repaired .other wise you would have to replace the tuner
Dec 25, 2008 | Toshiba 32A33 32" TV
Tv remote for 32 inch toshiba flat screen tv
tohhiba codes 062,064,085,229,231,385. for cable tv converters use 019.
Oct 22, 2008 | Toshiba 32AF42 32" TV
Cable tv won't work on my TV
go into the menu of the tv and program the channels into it. you will have to tell the tv if you have cable or a anntena, then select auto program. if you do this and the tv still has no channels, try unplugging it for 30 min and try again, if still not working it needs to go into a repair shop.
Mar 20, 2008 | Samsung TXL3276 32" TV
36 inch toshiba Tube tv manifactured in 1997
Program TV =
1) set-up.....Select CATV also called STD Cable
2) Auto-program channels.........
.......Owners manual ? Let me know.................T.
Dec 11, 2007 | Toshiba 32AF43 32" TV
Distorted television image
bad caps in power supply and poss. pincushion section.
Dec 06, 2007 | Toshiba 32AF43 32" TV
Toshiba 32A41 32" TV Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
