Question about Protocol Manta 4-Channel Radio-Controlled Quad-Copter
I can't find a way to change mode 2 back to mode 1. I also am having trouble siinking, I believe it is due to the mode but I am not completely sure.
I have tried the pre-flight directions and they aren't working for me. I have even pressed every button and I am sure that the plane has power. I have the plane turned on and I have the remote as well.
  • 3 Answers
Turn on remote control first then heli
Posted on Dec 26, 2013
  • Callie Browne
    Callie Browne Dec 27, 2013
    I just got my plane so the remote should be fine. I also have batteries inside of the remote.. I just can't change the mood from 2 to 1.
  • Callie Browne
    Mode**
I have probl?me code c111 for bizhub 601
let us try out this method lina lina never know that error code will disappear.
1. While pressing the utility/counter bot
1. While pressing the utility/counter bottom, turn ON the power switch SW2.
2. Trouble Reset screen appears.
3. Press the [Trouble Reset] key.
4. Enter Service Mode Stop>0>0>Stop>0>1
5. When CE password has been set, enter it.
6. Service Mode Menu Screen appears
7. Conduct necessary operations and turn OFF the SW2 after completions.ton, turn ON the power switch SW2.
Jan 26, 2016 | Office Equipment & Supplies
Trouble-shooting non-starting
When you perform the key dance of normal heat dry normal heat dry, that is DIAGNOSTIC MODE. The heavy black material is called "mastic" and has come loose from inside the door panel--the door panel must be replaced. I've seen the mastic come loose from heat and fall out of the bottom of the door. It acts like an insulator for sound and heat. It helps keep wires in position, etc. The dishwasher stopping could be from a clogged filter in the main pump, or a clogged drain motor. If the drain action is too slow, the computer will time out and stop. If the main pump is strangled for enough water due to a blocked filter, it will shut down to protect itself.
Aug 17, 2015 | Maytag Dishwashers
Tourble code in 0510 in konica minolta bizhub 36
Do not continue to reset or a fire could occur and that would ruin a perfectly good day :) Code is for the FUSER!!!! (HOT PART) IF CODE COMES BACK replace the fuser
Start:
A. Call the service mode to the screen.(Shifting to the service mode is available even when the service call is occurred).
1. Press the Utility/Counter key.
2. Touch [Meter Count] on meter count display.
3. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
4. Touch [Password], and enter the CE password using the display keyboard or the 10-key pad. Default is 92729272 (get three shots only then you are locked out)
B.Once in service mode use the following procedure
2. Change the screen using [?] / [?] and select [Trouble Reset].
NOTE
• The trouble reset key will be displayed in the service mode only when the service call is occurred.
3. Touch [OK] on the check screen.
4. According to the description on the screen, turn OFF the power switch, and turn it ON again more than 10 seconds after and check to make sure the machine operates normally.
Dec 27, 2013 | Konica Minolta bizhub C250 All-In-One...
No video signal
You can try these Trouble Shooting steps:
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
Safe Mode:1. Restart your computer. 2. Before the windows logo you should gently tap the F8 key repeatedly until you are presented with a Windows XP Advanced Options menu. 3. Select the option for Safe Mode using the arrow keys. 4. Then press enter on your keyboard to boot into Safe Mode. 5. Do whatever tasks you require and when you are done reboot to boot back into normal mode.
Video Card:1. Unplug all of the cables.2. Unscrew the tower.3. Remove the video card from the PCI slot.4. Use an eraser to erase the coper pins on the video card. It will remove the dirt from the pins.5. Insert the video card in the PCI slot.6. Screw back the tower.7. Plug back the cables.8. Turn on the pc. It should be working after these steps.
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
Dec 01, 2011 | HP Pavilion a1700n PC Desktop
E000 error
this is error for fixing temperature fault due to faulty heater lamp or thermistors.
If the trouble is temporary you can reset it in service mode.
Procedure:
Press the user mode key ( * ) and ID key on keypad ( # ), with help of arrows go trough the service mode to CLEAR and press OK, choose ERR and OK.
After clearing if the error is still on, you need to change the fixing unit. Because of legal and safety regulations, replace the whole fixing unit with new one from original manufacturer Canon.
Eaven if it's only lamp or thermistor trouble, replace the complete fixing unit!
Hope that helps!
Sep 17, 2011 | Canon imageRUNNER 2010F Copier
Setting is stuck on VCR, cannot use DVD functions or figure out how to change it back to DVD
This can be due to many faults as the VCR function has not come back to the MODE STOP/REST /CONDITION and so the processor tends to drive the mechanism to complete to the mode .
Hence please check up with these tips.
1. If the cassette does not loads or if the cassette is locked inside then the machine will shut as the loadind or the servo is defective.
2. If the in detect is not working then the opto devices or proximity sensors/magnetic type can be faulty.
3. If the drum does not rotate it will shut down as well a fault in the SERVO section.
4. Defective HALL IC can shut the switching and so the servo will shut down the processor.
5. Fault in the power section to deliver the correct voltage to the circuits/loading servo to take up.
6. Finally if the loading is not to the MODE switch point or failure of mode can make the loading to trip as it will not complete the load to the desired point.
Aug 25, 2011 | Sylvania DVR90VG Video Recorder
I have 26 trojan virus's. How do i get rid of them if my windows essential won't open due to the virus's?
First, you need to get a copy of AdAware from Lavasoft. They have a free version. You may need to run this 2 or 3 times to get most of them off.
Second make sure you have the latest version of your antivirus software updated. If you do not have antivisrus software you need to get a copy. There are free versions of that online as well.
If you are having trouble getting them installed because of the viruses, copy the files to a flashdrive from another computer, Without connecting your computer to the network load and install the files using the flashdrive. You may have to use safemode.
If that does not work let me know what messages you are getting.
Apr 07, 2011 | Dell Inspiron Mini 10 Notebook
How do I reset the computers timing belt information in a Toyota 2007 4.7L (VIN T, 5th digit, 2UZFE eng, 8 cyl) after making a timing belt change?
1. T-BELT MODE DISPLAY
a) With ignition turned ON, using the trip switch (select/reset button) change the display to ODO, and turn the ignition OFF
b) While pressing the trip switch, turn the ignition switch ON and hold it for 5 seconds.
c) Release the trip switch, then press the switch again within 5 seconds.
d) The digital display should change to T-belt mode. The initial display "15" (0,000km) is displayed (ie. 150,000km).
2. REWRITING REPLACEMENT VALUES
While in the T-Belt mode, each press of the trip switch will change the displayed value by 10,000km increments. Once " 20 " (200,000km) is reached the display reverts back to " 1 " (10,000km) again. Remember, this setting is the number of kilometres to be travelled before the light comes on next, and once reset this counter will start from zero.
I believe the timing belt interval for all the 100 series engine variants is 150,000km, but this should be checked against each different markets servicing recommendation. This being the case, you shouldn't need to change from the default setting of "15".
Obviously for the US, the ODO is in miles, and I guess the T-Belt warning would be set in 10,000 mile intervals.
3. T-BELT WARNING RESET COMPLETION
a) After setting the replacement setting value, hold the trip switch ON for more than 5 seconds then release the switch.
b) Check that the display has now changed back to ODO and that the warning light has gone off when the engine is started.
NOTE: If the T-Belt mode is completed, even though the belt replacement has not been performed, the T-Belt warning IS reset.
Oct 30, 2010 | Toyota Tundra Cars & Trucks
I change the tv # 2 and now I can't get to set the signal
Hey! My name is Becki Barned, and I am with Dish Network customer service! You have already gotten this issue resolved, but here are some steps in case you haven't! On tv2, try channel 60 and then 73. if that doesn't work, try to go to tv#1, press menu 6-1-5. Here, change (under tv2 out) the MODE setting from AIR (if it is on air) to CABLE, and vise versa. If the tv cannot go up past 69, make sure that the MODE is set to AIR. That's changing the setting for the TV#2, and with a new tv, this will usually fix it! Blog if any troubles!
Aug 21, 2010 | DISH Network 322 DTV Receiver
Our Sony 32sxr10 turns completely red after an amount of time. Sometimes you can tap the side of it and it will go back to normal. Other times, you have to turn it off or unplug it for a few minutes. We...
2 possibilities. 1 bad connections on the crt drive board. You can try removing the cover and looking at the PC board that is connected to the CRT (picture tube). If your lucky you will see tiny circles around some of the solder joints. Make sure you turn off and unplug and resolder the bad connections. The other trouble is the CRT itself this you can't fix and I don't believe the part is even available anymore.
Mar 15, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Protocol Manta 4-Channel Radio-Controlled Quad-Copter Logo
692 people viewed this question
Top Protocol Toys Experts
scamatics777
Level 1 Expert
 Mikey
Mikey
gmduvall
Are you a Protocol Toy Expert? Answer questions, earn points and help others
