Question about White Sewing Sewing Machines
White 3100 just knots in stitching
When sewing anything, the machine just stitches knots and skips. Called the manufacturer's troubleshooting line and they suspect the timing belt. Is this easy to fix on my own? We moved a few times so it had a few jostles so it may be possible that this could have something to do with its new knotting while stitching scenario. Any other possibilities- I don't want to go through the time in searching for the part and repairing if it could be a slew of other things.
    Champion:
  • 276 Answers
When you say knotting, do you mean a snarl up of looped thread on the underside. If so check top thread tension
Posted on Feb 19, 2014
4 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: machine won't stitch a complete stitch
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
So if the threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
If tensions appear correct, and the thread is definately in the channel between the discs, try raising presser foot, remove thread and with a strip piece of fabric 8 - 10" (20 - 25cm) gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without being shown, it may end up with missing small screws and spring pieces.
Hope this is of some help,
Bargainbox
Posted on Jan 20, 2008
  • 18 Answers
SOURCE: singer 5525 sewing machine knots
You can go here, search 5525, and download or purchase an instruction manual for your machine, if you have misplaced the one that came with it. It looks like there are some available as downloadable pdfs for free and some physical ones for $15. https://www.singerco.com/accessories/manuals.html
Also, Singer has just installed new Q&A features on their website. You can go here: http://new.singerco.com/products and look for your particular model or machine category. At the bottom of the product page, you can post Questions for singer experts and other community members to answer!
Posted on Jul 22, 2010
bugoy31
  • 1238 Answers
SOURCE: keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Posted on Jun 06, 2011
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Basic Maintenance Tension Skipped Stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
White Style-maker 3100 knotting
again check needle thread tension
Dec 26, 2013 | Sewing Machines
My white sewing machine is skip stitching
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 27, 2009 | White Sewing White 3032
Sewing Machines Logo
73 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
