Question about Measuring Tools & Sensors
I can not put the track together on my magna moto magnetic track set
How do I order
http://www.amazon.com/s/?ie=UTF8&keywords=magna+arm&tag=googhydr-20&index=aps&hvadid=34601805648&hvpos=1t1&hvexid=&hvnetw=g&hvrand=12532063791080661631&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_6hykn25j93_b
Jan 05, 2015 | Televison & Video
Resistance does not increase
please read the instruction and fix it. God bless you
Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.Test with the magnet from a refrigerator, If the magnet attract and repulse, is o.k If not replace the magnet.1_21_2013_5_29_53_pm.gif
Jan 20, 2013 | Schwinn 420 Elliptical Trainer
Magnetic issue with magna doodle
You might have gotten a bad magna doodle you might have to call the company and get anew from them.
Dec 30, 2012 | Mattel Fisher Price Magna Doodle (PC)
Purchased a Lionel New York Central Flyer Operating Freight Expansion Pack with a coal dumper. My set runs on O-gauge track, not fas track, but the magnet operation appears to be the same. The coal...
The magnet may not have enough punch using track power. Recommend you use an aux power source fixed 10 to 13VAC supply and not track power. There may also be a slight + difference between the track magnet head and the plate on the coal car so that there is insufficient force to release the dump mechanism.
Apr 22, 2011 | Lionel New York Central Flyer
I am not able to put this train set together some tracks have letters others numbers
the tracks with letters are misty island put c and d together for corners (swap other side) then rickty bridge inbetween on one side and switch track on other. For numbers pretty much you can go by number (start with 1 and go left) I had to fidget a little but it worked
Jan 08, 2011 | Hit Thomas the Train Misty Island Deluxe...
I have a rio grande train set and I can not figure out to put the tracks together?
HOLD TWO PIECES OF TRACK TOGETHER SNAP ONE SIDE TOGETHER THEN SNAP OTHER SIDE.
May 28, 2010 | Scientific Toys North Pole Express Xmas...
Our tv is magnitized by our surround sound base speaker what can we do.
Hello. Here are the steps:
1.put your hands in the form like you would if you are about rub your hands together for warmth
2.Put the magnet between both hands at the palm areas
3.rub your hands together and turn the magnet so that the north and south ends magnetize the TV simultaneously
4.make sure you know where the north and south ends are located on the magnet
5.Hint - The Constant switching between the north and south polarizations causes the magnet to equalize the magnetized areas on the TV returning it to it's original color!
Regards, Joe
PS kindly rate my answer. thank you.
Jan 24, 2010 | Quasar SP-3235 32" TV
How to take the ignition off to key key code number on a 1995 Honda VF750 Magna
Remove the tank and the top triple clamp. You might need to buy a security tip for the bolts under the triple clamp. Chaz Moto Dc
Jan 21, 2010 | 1995 Honda VF 750 C Magna
Scalextric cars won't negotiate banked curve on track
after watching james may's programme the other week you need the cars with the magnets inside
Jan 03, 2010 | Scalextric Toys
Measuring Tools & Sensors Logo
21 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
