Question about Wildgame Innovations IR4 Digital Camera
Camera doesn't work, no green light - Wildgame Innovations IR4 Digital Camera
Kodak z650 comes on fine but doesn't stay on-funny noise before it cuts off
Hello Donna, You camera is suffering from age, needs to be repaired or time to replace it. Sorry.
Nov 02, 2012 | Kodak EasyShare Z650 Digital Camera
My webcam doesn't work. The green light shows up next to it, but when I come to view through the camera all I can see is a black screen. It literally doesn't show anything, even lights.
Hi cazjenks...
Try this solution to your problem
Follow the instructions below to use your webcam
Click on Start then >Control panel>hardware and sound >device manager>imaging devices>web cam....enable it
Another way is to use a IM application like Yahoo messenger,NetMeeting,etc. They will have video capabilities that will work with your webcam.
Please take time to rate me thumbs up
Sep 10, 2011 | Computers & Internet
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
Brand new Nikon 3100 with freshly charged battery will not turn on for the first time. When I install the battery and close the flap, a small green indicator light lights up, but that's it. On/Off...
Well you have 2 choices...don't go back to Best Buy because you don't want to and you'd rather live with a brand new camera that doesn't work or.....take it back!
Sep 04, 2011 | Nikon D3100 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My camera wont charge, when i plug in the camera the green light will blink several time and then disapear
It's probably a worn out battery. The batteries are good for 150-300 charges. Every connect is a charge. Doesn't take long.
Jun 18, 2011 | Nikon Coolpix S4000 Digital Camera
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
My camera has a black screen even when is on
It does not look good.
Here are some problems which could be with this camera:
LCD broken or bad.
CCD problem.
Since you go have some light on the green light, then that appears to be a LCD problem. this can happen if the camera had an impact to cause the LCD to be damaged or disconnected in some way.
For further help:
Go to:
http://vivitar.com/en-us/Support.aspx
Ask for your model.
Sep 18, 2007 | Vivitar ViviCam 5100 Digital Camera
Wildgame Innovations IR4 Digital Camera Logo
82 people viewed this question
Top Wildgame Innovations Cameras Experts
teddyboy
Steve Mason
Are you a Wildgame Innovations Camera Expert? Answer questions, earn points and help others
