Question about Weslo Cadence 60 SE Treadmill
Weslo Cadence 60 SE display not working - Weslo Cadence 60 SE Treadmill
mohtwister
  • 37 Answers
SOURCE: Lost owners manual
try this: http://fitness.owneriq.net/manuals/mfg/weslo/cadence_450_model_no_wltl35520.html
Posted on Jun 02, 2009
  • 16 Answers
SOURCE: i have weslo cadence 860 ,the key is not working
Is it the magnetic key or the red one you slide into the slot.
Posted on Jun 29, 2009
SOURCE: lost key for my weslo cadence 860
We found the key.
Thanx
Posted on Sep 03, 2009
hasan mahmud
  • 35 Answers
SOURCE: weslo cadence treadmill fuse keeps tripping after
dear sir,
this types of problem occurred due to reason given below:-
1) if your motor belt too jammed. motor need more power to rotate it.
2) motor internal coil insulation problem.
3) semi short circuit in the internal control circuit.
how to check :-
at first look the label on motor try to find out the motor Ampere then measure with a ammeter if it drawing current is high from label mentioned ampere
then motor is faulty.
for check the circuit if u don't have any previous idea plz contact with qualified technical person.
hope that u get the answer.
thanks
Posted on Oct 22, 2009
SOURCE: i have a weslo cadence 845 treadmill and i lost the key.
use a magnet
Posted on Mar 23, 2010
The belt is skipping
hi,
You have to tension the belt of your treadmill. Here i have added a video which will help you to do the same. All the treadmills hve the same procedure.
ok
Aug 04, 2011 | Weslo Cadence 60 SE Treadmill
Don't have a manual......how do you turn on?
hi in the front bottom of the treadmill there should be a power on switch, turn this on and next to that there should be a power breaker switch turn that on also. now you should be ready to go! if still nothing telephone 08451770512 this is the number og the main suppliers of weslo cadence treadmills, local call and i am sure these people will help.
Nov 11, 2010 | Weslo Cadence 60 SE Treadmill
ONLY 2 WORKING BUTTONS!?
just replace the keypad, whit rhe number of model and serial
Feb 04, 2010 | Weslo Cadence 60 SE Treadmill
Need Operating Manual for weslo cadence 60 ct treadmill
i have this treadmill n i can get it to stop going fast
Jan 07, 2010 | Weslo Cadence 60 SE Treadmill
I have a weslo cadence tredmill practily new its been in a corner maybe a year went, to get on it no power please help if you can, thank Marsha Willis
check on/off switch located in frt of item where power cord goes in....and if that works, since its been just sitting there folded up, lubercation will be needed under walking belt-do not use silicone spray or wd-40. it has to be a special lube from manufacture-find manual,there is phone #, ask 4 parts dept, tell them u need lube of item, they and send with credit card let me know when u get, i will tell u how to apply lube, its easier then making coffee...david
Jan 06, 2010 | Weslo Cadence 60 SE Treadmill
My weslo 860 was in use, it then just stopped but the screen was still reading. it also had a burning scent coming from the motor area
Sounds like motor controller just burned out. If elevation and other function starts normally but belt doesn't move that your problem.
Nov 15, 2009 | Weslo Cadence 60 SE Treadmill
When the tread mill is running at a set speed, it for no appearant reason speeds up super fast with no one touching any button?
The motor controller controls the speed of the motor. This part usually work or dont work but I have seen a few instances where it was just going bad.
Jun 05, 2009 | Weslo Cadence 60 SE Treadmill
Weslo Cadence 60 SE Treadmill Logo
26 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Jim London
Jim London
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
