Question about GE Refrigerators
GE Artica PSS29NGNA no ice is being / no water flow on ice side
I have a GE Artica PSS29NGNA no ice is being made. First signs of problem was overflowing tray which built up ice and broke the plastic seperator. Replaced ice maker but now no water flow at all. Plenty of flow from the door. Turn switch off and on, the arm will rotate and 360 deg and stop but no water. Any ideas? Thanks!
  • Anonymous Mar 19, 2014
    When you turn the ic maker switch on and off the arm does not swing, i ohm checked the water valve and it appears to be ok. checked the door switch and it appears to be ok. I think i may have a bad Ice Maker..
  • GE Master
  • 4,655 Answers
It is possible the water control valve on the back of the refrigerator is defective. When the thermostat in the ice maker tells the water control valve to ope after dumping the ice. Try filling the ice maker with tap water and let it freeze and cycle one time. It is also possible that the fill tube for the ice maker has frozen shut because of the slow continious flow of a leaking water control valve. You can try to clear the ice with a hair dryer, but if the control valve continues to let water buy will have another damaged ice maker. The part number for the water control valve is WR57X10032 and you can enter parts numbers and model numbers on the search feature at the link below. Let me know how thing are and if you were able to get this under control, I am here to help if you like, sorry I just today saw your post, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 21, 2009
GE Artica no water, no ice, Checked water supply to solenoid OK
did u check water line after solenoids. could be a vaccum or u could have bad solenoids, not opening to allow water to go into box, try ok.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Dec 09, 2009 | GE Profile¿ Arctica® Energy...
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice and water working intermittently, makes ice, Artica PSS 26NG
Go into the test mode and use 0 4 as the test code between the dispensor board and the main board .(communication test) Sounds like the main control board though .
Jul 18, 2009 | GE Profile¿ Arctica® Energy...
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE artica, 6 years old has freezer temp at 35 degrees , and refrigerator at 50 degrees. Water is flowing from dispenser, as normal but there is no ice. Ice/frozen things in freezer melted and water...
Check the back wall of the freezer for a ice buildup.
If ice is there you have a defrost parts issue.
That will cause the temps you report.
Also, check the freezer fan motor.
Is it running?
Also check the condenser fan motor at the compressor. Is it running?
Mar 03, 2009 | GE Refrigerators
Ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
571 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
