Question about Dell Optiplex 755 Desktop Desktop Computer
Black screen missing operating systems and I dont have the bootable cd or floopy.
    Brigadier General:
  • Dell Master
  • 3,400 Answers
THAT YOU HAVE TO EXPLAIN BETTER.
Posted on Dec 26, 2013
Please help me..i have a aspire one d260 netbook..the problem is bootmgr is missing..it has no cd drive and i dont have a external cd drive to use.. how can i fix it using only a usb flash drive..how can...
You might have to take it to the shop. Lesson learned. Never buy a computer without a CD Drive because one day the system is going to croak.You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 29, 2012 | Acer Aspire One D260 Netbook
Black screen on start up with blinking cursor
Chances are, the operating system is corrupt.
Solution 1
1. Restart the computer, before entering the windows, press F8 to open the Windows Advanced Options Menu.
2. To enter the windows, select Last Known Good Configuration - enter. If that fails, repeat the process, select the Directory services restore mode. If that fails, repeat the process, select the Debugging mode.
3. After successfully entering the windows, press START - All programs - Accessories - System Tools - System Restore. Restore to a date when the computer is in normal condition.
Solution 2 (if the above solution fails)
Repair windows operating system with a bootable CD
Windows XP
1. Insert the bootable operating system CD, and restart
2. Perform booting from the CD room - Enter
3. Press enter - F8 - press R to repair the operating system
4. Wait until the process is complete. Finish
Windows Vista or Seven
3. Select Repair your computer - System Restore. If that fails, repeat the process 1, 2
4. Select Repair your computer - CompletePC restore. Restore a computer from CompletePC Backup Image.
Solution 3 (only for Win XP)
When done repair the operating system, drive C is detected: unknown or not formatted, it means the C drive for bad sectors.
To fix hard disk bad sectors, use the software HDD Regenerator bootable CD.
Nov 23, 2011 | Toshiba Computers & Internet
I dont know how to install the microsoft
microsoft operating system comes in different version, windows xp , windows vista and windows 7. ecah one have bootable CD, what u need is to put bootable cd in your cd room and boot it from cd and it will show step by step how to install
Sep 16, 2011 | Computers & Internet
My laptop will not boot up, instead it goes directly into a screen I haven't seen before and says, "Operating System not found"
usually this means that the previously installed windows/linux operating system is corrupted....best to re-install operating system via disc windows/linux....so that it replaces corrupted informatiom/instructions on hard drive....if you have files you want to keep then dont do a format on install as you will definately lose them......
Jun 12, 2010 | IBM ThinkPad R40 2722 Notebook
NTLDR is Missing Press Ctrl+Alt+Del to Restart Problem! No CD No Floppy to reboot! How to fix it?
its necessary to you a bootable cd or floppy system disk. ntldr is part of the hard disk partition data, it this partition if missing then you cannot open your system until you use bootable operating system.
Jul 15, 2009 | Compaq Evo D500 PC Desktop
Make MS-DOS Boot CD
Hi. This adress (http://www.bootdisks.us/ms-dos/5/ms-dos-bootable-cd-images.html) contains a couple of ready boot discs. Just download them (.iso file) and burn them to a CD. Hope this helps.
May 22, 2009 | Microsoft MS Windows XP Professional SP2
I have an old G3 and when I power it up it gives me a floopy disk in the middle of the screen with a ? mark flashing I have no start up floopy can you let me create one
You could try to start from the Disk Tools PPC (can be found here; the Disk Copy 6.3.3 utility, and another Mac with a floppy drive, would be required to make a bootable floppy from the disk image). Otherwise, an appropriate version of the operating system on CD will be needed.
Apr 10, 2008 | Computers & Internet
DESPERATE
yes you can but to help I need to know what operative system will you use to do it, which one you are going to bootup with... (better if its the same) and of course any info you can give...
Mar 29, 2008 | Computers & Internet
Windows xp instalation
use bootable original XP CD ROM ,
First : Insert CD in to drive
2-Go to BIOS change the bootable priority as boot from CD
3-Enter serial number when asked
4-give necessary answer
After 20 minitus it complete.
Nov 26, 2007 | Microsoft Windows XP Professional With...
Dell Optiplex 755 Desktop Desktop Computer  Logo
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
