Question about Cuisinart DCC490SA Coffee Maker
I have a Cuisinart Automatic Grind and Brew Coffee Maker, Model DCC 490SA, Serial 508130. For some reason, I have been unable to turn it on manually (with the on/off switch) for some time, but could start it by setting the timer. Now I cannot start it at all. It is getting electricity, as the clock is working, and I can set the timer's start time, but when I turn the knob to actually turn the timer ''on'', it will not do so. I'm not sure how old the coffee maker is; but I think about two years.
    Top Expert:
  • Cuisinart Master
  • 40,262 Answers
The switch, the timer, or both are defective.
Posted on May 11, 2017
SOURCE: I have a cuisinart automatic
On mine the door that holds the ground coffee in place at times doesn't latch properly either and then the it will pop loose. I have to close it fairly hard in order to get it to latch and I test the latch by pushing on the door to see if comes open. When properly latched it will only open via the little button on the side, not by jiggling the door.
Posted on Jul 23, 2008
  • 8596 Answers
SOURCE: cuisinart automatic grind and brew
Clean it out with vinegar and water - 2 ozs distilled white vinegar, 2ozs water
Posted on Dec 15, 2008
  • 1952 Answers
SOURCE: Need Manual for Cuisinart DCC-1150BK Coffee Maker
try this site.
Posted on Jan 06, 2009
  • 8596 Answers
SOURCE: I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Posted on Mar 21, 2009
  • 8596 Answers
SOURCE: Coffee maker, bought used cuisinart grind &brew, how do i use it?
Setting the Clock:
When the coffeemaker is plugged in, 12:00 will
flash continuously until you set the time.
Entering “Time Set” Mode:
To set the time, hold down either the “Hours”
or “Minutes” button until the clock stops flashing
and begins to count up (about 2 seconds).
You are now in the “Time Set” mode and can
operate either button to achieve the desired
setting. The buttons can be held down to scroll
through the digits, or pressed and released
lightly to advance one digit at a time.
When scrolling, the numbers will advance
slowly at first and then speed up to the rate
of about three per second. When the number
displayed approaches the desired setting,
release the button and press repeatedly to
advance one digit at a time. Be careful to
make sure that the PM indicator is on if a
PM time is desired.
Exiting “Time Set” Mode:
The “Time Set” mode can be exited in
one of two ways:
1. Press any button besides the “Hours” or
“Minutes” button. This will exit the “Time Set”
and activate the selected function.
2. Do nothing. If neither the “Hours” nor
“Minutes” button is pressed for a period
of five seconds, the “Time Set” mode will
be exited.
Posted on Mar 22, 2009
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here:
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Can the circuit board be replaced on a cuisinart model dcc 1150
it can but!! i never could ge them to sell me just the board i usually had to repair the one i had
Jan 23, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Dec 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind & Brew DCC 490
ask, they have it.
Sep 10, 2008 | Cuisinart Coffeemakers
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Automotic Grind & Brew Coffee Maker
Jun 02, 2008 | Cuisinart DGB-600 Coffee Maker
Coffee Makers & Espresso Machines Logo
502 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
