Question about Polaroid One600 Pro Instant Camera
How to turn it on
It works fine when plugged up to the computer but when i unplug it it wont turn on
Light underneath turns on, but cursor doesn't move and I can't click anything
Unplug it, restart your computer and try it again. Only this time plug it in before you restart the computer. It should detect the new hardware. If that doesn't work, try another USB port. Could be a problem with the internal functions of the mouse also. Good luck
Jan 03, 2014 | Inland Navigator (07233) Mouse
It was working fine an hour before the problem started happening. now when plugged into a computer it is normal. when unplugged it usually stays on but now its just blank and off. earlier it would turn on...
The battery wire must have come off...Sansa clip has this problem...u'll have to open the sansa clip and solder the battery wire in appropriate position..
Aug 11, 2009 | SanDisk Sansa Clip MP3 Player
My sandisk sansa 2g wont turn on with out being plugged in at tha computer n seems to be fine when its plugged in but when its unplugged it wont work! the battery is on a full battery but wont turn on at...
The battery may show "full' but still not hold a charge, so that when you unplug it from your computer, it goes dead. I assume you hold down the power button for several seconds and it still doesn't power up? Most likely, you battery is defective.
Feb 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Kodak EasyShare C613 turns off when connected to PC
The camera is supposed to go blank when connected to computer.
I hit the "share" button and can then download photos, even though screen is still blank.
Feb 25, 2009 | Kodak EasyShare C613 Digital Camera
E-machine was working fine last night got up and it turns on but the monitor says check cable or power but all is ok.Computer wont display anything, can anyone help?
Do a reset: Turn the computer and monitor off. Unplug the monitor video cable from the computer and unplug the monitor power cord from the wall outlet. Let it sit for 5 or 10 minutes. Plug everything back in, turn on the monitor, then start the computer. Sometimes that will work.
If you still have the same problem, try to borrow a known to be good monitor from somebody. If it works, then you know your monitor is bad.
It's also possible that your video circuitry is bad. If the monitor plugs straight into the motherboard (onboard video), then you'll need to purchase a video card and install it. Disable the onboard video first.
Feb 25, 2009 | E-Machines (T2958) PC Desktop
Laptop no power, power cord lights up
You should try unplugging the laptop from the power and taking out the battery. Then after about 30 seconds plug the battery back in and attempt to turn the computer back on.
Feb 02, 2009 | Toshiba Satellite M40-S417TD Notebook
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Polaroid One600 Pro Instant Camera Logo
Top Polaroid Photography Experts
luminos8
Level 1 Expert
danoyachtcap
danoyachtcap
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
