Question about Logitech Z5400 Speaker System
Subwoofer logitech z5400 not work - Logitech Z5400 Speaker System
Why is my HP Designjet z5400 only processing a PDF but will not print it without an error message coming up?
First of all, can your so called pdf open in Adobe Acrobat Reader, if not, then you need to first convert your JPG into a PDF. You need a program to do this. But if you can open it in Reader, then you need to print it from there. Try one of these solutions.
Jul 03, 2015 | HP Designjet Z5400 PostScript Inkjet Large...
Logitech R-20 subwoofer not working on windows 7
This undoubtably is a driver problem. You could try running and installing in Administrator, mode and compatability Mode for XP SP2. Either that or ask Logitech whats their fix.
Feb 06, 2010 | Logitech R-20 Computer Speakers
Subwoofer stopped working
After time they may collect dust. clean them a bit.Do u have an extended warranty. may your should use it . if that does work maybe time for an upgrade..
Sep 06, 2009 | Logitech R-20 Computer Speakers
My logitech z 2300 subwoofer is not producing sound
Since this set is hardwired together and the other speakers are working, the only easy fix would be the subwoofer got turned down on the remote volume control. Anything more would mean its broken. If its under warranty take it back. If its not and you know somebody capable, you might have them check for the obvious,bad solder connections on speaker, or and open voice coil on the speaker it self.
Aug 26, 2009 | Logitech Z-2300 Computer Speakers
Center/subwoofer speaker out...mixed
Hi all, I also purchased a logitech x-540 a few days ago and also have the center speaker outputting sound when i test or play the subwoofer. I didn't think this is normal and am now confused. Maybe its a problem with the audio drivers? MB is a ASUS P6T Deluxe V2 with Soundmax drivers. Hopefully someone can help to diagnose/ find a soluytion.
Jun 27, 2009 | Logitech X-540 Computer Speakers
Subwoofers not working on Logitech R-20 speakers; worked until recently
did you fix it? I have exactly the same problem, I'd appreciate any help please
Jun 03, 2009 | Logitech R-20 Computer Speakers
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Jul 17, 2008 | Logitech R-20 Computer Speakers
Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Jan 12, 2008 | Logitech Z-2300 Computer Speakers
Z5300e Subwoofer Problem.
in my view, it is due to any of the following
1. its fuse burnout or wire breaked, check fuse and cordwire
2. its subwoofer coil is damaged to loud volume, replace it
3. its amplifier IC is damaged, replace IC
Dec 31, 2007 | Logitech Z-5300 Computer Speakers
Logitech Z5400 Speaker System Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
