Question about ASUS B400A-XH51 14.1" Ultrabook PC Computer
Install ram Asus B400A
How to add RAM
4 Suggested Answers
SOURCE: Asus 1000 freezes after 2g ram upgrade
Go into bios and make sure mem is set to auto find ,might help
Posted on Mar 04, 2009
botaksetan
  • 80 Answers
SOURCE: i changed my1G ram in my asus 900ah to a 2g CrucialDDR2
As reported on the EeeUser forum, the EeePC 900 is somewhat picky with RAM upgrades. If the RAM chip is not exactly spec’d like the stock RAM module, then the computer would be prone to freezing, especially when switching between battery and mains power.
Also, note that the RAM module that came with the EeePC 900 is an AData PC2-3200 (running at 400 MHz) with part number DOGC1A08342. I find it strange that the chip is a 400 MHz one. Even the original 512MB chip that came with my EeePC 701 was a 667 MHz one!
This means if you plan to upgrade your 900’s RAM, better make sure the module is compatible!
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Posted on Mar 20, 2009
2pagescouk
  • 325 Answers
SOURCE: i want to add RAM
general answer not specific to this model as I don't know it..but
If its not entirely obvious where to add memory then there is a possibility it is under the keyboard, see if once you have undone any screws (particularly any with a picture of a keyboard) then gentry prise the keyboard up ensuring you dont snap off any keys.
Posted on Mar 17, 2011
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Nvdia 9400 gt on P5GD1-TML/S
Yes, your mainboard supports up to 2GB of DDR memory. That does not change if you add a graphic card. Windows XP 32 bit can actually address up to 4 GB of total memory including CD, hard drives, and video cache.
Note: Your mainboard only supports up to 2 GB, but newer boards can support much more memory, up to 16GB of RAM.
If you could install 4 GB of RAM in your machine, it would still work, but windows would only address as much RAM as it can use; the rest would go unused, so it would probably show up as 3.5 GB of RAM then.
Jan 05, 2012 | ASUS GeForce Computers & Internet
Does ASUS P5GC-MX/1333 Motherboard supports DDR2 800mhz ram.?i'am havin 1gb ddr2 667mhz ram and i want to add 2gb 800mhz ram to it
Hello Tarun - No it doesn't. It would run OK but you would not gain any performance as the ram will only run at the same 667 MHz.
The limitation of RAM speed is dictated by the specs of the Intel 945 Chipset the motherboard is based on. But certainly add more ram, especially if your running Windows Vista or Windows 7 which both need at least two GB of RAM to perform well.
Happy upgrading and thanks for using Fix Ya.
Mikeywaf
Mar 21, 2011 | ASUS P5GC-MX/1333 Motherboard
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
Asus P5VDC-MX question about ram .
Hi
You can add one more 1GB ram module.
Max Supported RAM 2 GB Memory Type DDR2Supported RAM Speeds 400 MHz · 266 MHz · 533 MHz · 333 MHz
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
Need to increase the ram on the VGA Card
My friend you can add RAM on your VGA by purchasing another Higher Video card  RAM. you can buy 512mb (265 - 512 bit) VGA Card to increase your VGA RAM.
Jun 18, 2009 | ASUS P4P800-X Motherboard
Compatiblity issue..
You may install up to 4GB of DDR RAM in this motherboard. It does not use DDR2.
This is from your manual:
Dual-channel DDR400 memory support
Employing the Double Data Rate (DDR) memory technology, the motherboard supports up to 4GB of system memory using DDR400/333/266 DIMMs.
If you would care for the manual, here is a link:
Asus P5P800-VM Manual
Thanks for using Fixya.
Apr 03, 2009 | ASUS P5P800-VM Motherboard
ASUS P5GPL - Ram Capacity
if there is additional ram slots it will definitely support but the ram speed should be the same,like if u use the ram as 133mhz ,u should use the ram with same speed .
Feb 21, 2008 | ASUS P5GPL Motherboard
ASUS B400A-XH51 14.1" Ultrabook PC Computer Logo
24 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
