Question about Samsung Televison & Video
Tv lcd slow dark image
When watching the tv, the picture is dark and when them credits go up at the end of a programme, you can't even read then as they all go blurry, and merge together.. Sometimes it's fine, it was fine this morning, then we've been out all day, came this evening, put the tv on and this is what has happened, it was the same last night too. I wait to hear from you, thanks
    New Friend:
Sounds like a fault with inverter. What lamp have you replaced?
Posted on Dec 26, 2013
  • 3 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
  • 13 Answers
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Posted on Apr 28, 2009
  • 12 Answers
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Posted on Jul 07, 2009
SOURCE: Sometimes Loses Sound
disconnect the hdmi cable from both ends it resets the sound signal!!!
Posted on May 10, 2010
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
LG 32LC2DB television says No Signal after 30 min
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | LG Televison & Video
Sony KDL-40SL150 picture issue
There are two possibilities for the problems:
1. Defective T-CON;
2. Defective display panel.
I will try a new T-CON board first. We do not have the service manual for this model, sometimes the T-CON is built on the panel data/gate buffer board, if this is the case, you have to change the panel, it is not economical.
Nov 01, 2017 | Sony Televison & Video
Hi - I have a 42" Vizio and when the scene is dark (takes place at night or credits at the end of a film) the entire screen fades to dark. Help!
Used the tv original remote go into tv Menu goto PICTURE turn on more Backlight like +5 and like Contrast +30.The tv back ground should be alot brighter.
Sep 05, 2011 | Vizio VW42LF 42 in. LCD HDTV
I have a Samsung 46 " LCD that is 2.5 years old. We had 3 capacitors replaced about 2 months ago, tv clicked but wouldn't come on.Now we have a new problem. The picture will be dark for awhile and then it...
No,this problems it the T-CON decoders board problems.This board sit right in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 16, 2010 | Televison & Video
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture left of center bad on start up
Sounds like a bad display panel to me. Have you tried it with component input, or hdmi??
Aug 26, 2009 | Sony BRAVIA KDL-46W3000 Television
When I am watching a dvd with a dark scene it seems to get even darker almost to the point where I cant see anything.The light scenes are fine. Is there a setting I can change
try adjusting your brightness a little highter up and if you have a LCD tv you can adjust the backlight through your picture/video/image settings in your On Screen Display menu to your television
Aug 07, 2009 | GPX D1816 DVD Player
Mar 12, 2009 | Televison & Video
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
