Question about Kenwood eXcelon KDC-X879 CD Player
Kdc-x879 won't recognize cd feature
I have lost the ability to access the cd feature. The display does only gives me the option of tuner. sirus, and standby. I can not get the face to open to the cd player. It did work at one time, but no more. I tried pushing the reset button, but all that did was cause me to have to reset all  presets on my radio stations. can you help? Thanks
  • 132 Answers
Is the display messing up, lines through it? I work on kenwood units daily and most flip faces is the ribion cable ( I belive theres 2 in this deck)
Notice kenwoods new linup doesnt feature flip faces anymore.
Posted on Jul 16, 2008
    President:
  • 624 Answers
I am sorry to tell you this, but there is no easy fix after pressing the reset button. The unit is not even recognizing the cd player, so it could be one of many different problems, all of them being electronic and inside the unit.
It could be a voltage regulator that supplies the cd deck, it has 3 of them. It could be the ribbon cable that connects the cd deck to the main board, but that is more unlikely. It could even be the microprocessor.
There is just no way to be certain without putting it on a test bench and troubleshooting it with the schematic in front of you.
If you have some electronic troubleshooting skills, I can email the schematic to you. I have it in PDF format and you can check it out as long as you have a power supply, multimeter and knowledge of electronics.
Otherwise, you will need to take it in to an authorized Kenwood repair center.
I hope you found this helpful, but you do have a serious problem with the unit.
I have been repairing these type of radios since they started making them a couple of years ago and this problem has had several different fixes for this same symptom and it has never been an easy fix.
let me know if you need more help
Posted on Jun 22, 2008
SOURCE:
How do I get cd in cd player on KDC-X879?
Press Eject button top right to drop the front panel down, insert CD in to slot.
You can download the manual here:Manual
Jan 25, 2012 | Kenwood eXcelon KDC-X879 CD Player
The portable setting no longer comes up. instead
you may need to into the menu and turn the aux option back on.
Apr 20, 2010 | Kenwood KDC-MP828 CD Player
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
Unit only has power for a few seconds
could be a couple of things..1. issue with your ground connection 2. ventilation
May 29, 2009 | Kenwood eXcelon KDC-X879 CD Player
Yeah remove the unit from your car,
Go to car audio store and buy Kenwood receiver without the
fancy opening front.
Dec 17, 2008 | Kenwood eXcelon KDC-X879 CD Player
Code
the universal code used to be kcar but you have to have a specific type of remote to spell it out
Feb 23, 2008 | Kenwood eXcelon KDC-X879 CD Player
No CD
The normal source selections for this model when the SRC button is pressed are: TUNER, CD and STANDBY.
If there is no CD inside the tray, or if it is dirty, unreadable, inverted or damaged, then the CD source option will not display at all.
If the there is a known good CD placed properly inside the tray and the CD source will still not show as a source selection, you may need to RESET the unit. The reset button is near mid bottom. This will also erase all settings, memory and tuner presets.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 08, 2008 | Kenwood KDC-3027A CD Player
Kenwood eXcelon KDC-X879 CD Player Logo
82 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
