Question about 2002 Bounder 39r
Furnace does not ignite
Fan runs and times out does not ignite
  • 34 Answers
Could be the draft sensor or igniter. if you hear a click after fan starts but before timeout, then check igniter. does it glow bright yellow-orange? if not replace igniter. igniter is near gas orfice on manifold.
Posted on Dec 27, 2013
Furnace wil, not ignite when calling for heat
For this answer, we need a model and serial number.
Generally, be sure the power is on, does the heat moving device run? (Fan for air, or pumps for water)
Nov 02, 2017 | Heating & Cooling
Gas does not ignite on furnace. Fan stays on even when shut off at thermostat. When trying to start, I hear a click and get a gas odor that stops quickly. Furnace had major overhaul 10 years ago.
You have a ignitor problem .Replace the ignitor .Is it a direct spark or a glow type .My guess it's a glow type .About the fan issue sometimes fan would stay running for maybe a minute even after you turn the fan mode ofg
May 27, 2017 | Heating & Cooling
I have a evcon EB12B where is the reset button. The blower stays on even if heater is turned off at thermostat. I have to turn off in breaker box
This may need the furnace technician to repair.
I can locate the manual for your heater and the parts list but I cannot locate any reset button.
Blowers that run all the time have either a stuck fan relay or depending on age, have either a defective "fan control and limit switch" or a breaker that operates the fan. When the furnace ignites the fan waits until the air get hot before it blows. When the heat goes off, the fan continues to run until the furnace is cool.
You probably can replace the parts yourself but please make sure it runs safely. The making sure is what the furnace tech will do.
Apr 18, 2015 | Heating & Cooling
Bryant gas furnace does the blower motor have to work for the heat exchanger to light up both are not working
It depends....on if you are talking about a small blower in the front of the furnace or the indoor fan motor. If your furnace is an 80% effficiency rating or above it will have a 'combustion air' fan....that will be a small on in front of the furnace in the vestibule under the front cover. If you have that motor and that is the one you are asking about...then YES it has to be running prior to the furnace igniting the gas.
If you are talking about the indoor fan motor for circulating air into your ducts, then NO it does not have to be running in order for the furnace to ignite. But it WILL have to run to remove the heat from the heat exchanger after it ignites or it willl overheat and shut off on high limit.
Jan 02, 2015 | Heating & Cooling
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Ruud 80 plus furnace
Make sure you give it time. Gas furnaces ignite first and then the fan comes on. It will run for a while to heat the exchanger first. If the fan comes on with the heat it will blow cold initially. The fan also continues to run after the burners shut off to expel the existing heat in the ductwork
Oct 19, 2013 | Heating & Cooling
Carrier Weathermaker gas 8000 will not ignite
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
May 21, 2008 | Heating & Cooling
2002 Bounder 39r Logo
71 people viewed this question
Top Fleetwood Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Fleetwood Vehicle Part and Accessory Expert? Answer questions, earn points and help others
