Question about Verizon Wireless Jetpack 4G LTE Mobile Hotspot 890L
Accidentally blocked printer from Verizon mi-fi jetpack
Want to unblock printer
My system is mifi jetpack 5510l with 10 gb with android tablet teame to use less data
Spend less time playing online chess outside your house where you have to connect the MiFi Jetpack to your laptop and use your data plan and more time playing at home over your home network where you do not have to use the jetpack and your data plan.
Jan 01, 2015 | Novatel MiFi 5510L Jetpack 4G LTE Mobile...
Why won't it connect to my computer?
As long as you have service and the jetpack is turned on it is transmitting a wifi signal. On the bottom right hand side of your computer screen is an internet icon--look where your time display is and this icon is just before the time. Click this internet icon and it should recognize the Jetpack signal. If it does, it will say "connections are available" right click on that and it will show available connections including the jetpack. Right click on the identified jetpack signal and then click on "connect" and enter the security key and now you should have full internet access. If, when you click on the internet icon, it does not say "connections available", then click on "troubleshoot" and let the device tell you what the issue is preventing connection.
Jun 17, 2014 | ZTE Verizon Jetpack 4g/3g Mobile Hotspot...
Verizon jetpack 890L won't take a charge. I have bought a new battery and charger still won't take a charge.
Does the power button light up when it is charging? If not, either the charger, battery, or device itself is defective. It could be one of the three or a combination of two. Since it does operate while plugged in, I would try yet another battery for it sound's most likely like a dead or weak battery is the culprit.
May 28, 2014 | ZTE Verizon Jetpack 4g/3g Mobile Hotspot...
My verizon jetpack MHS29IL shut down and won't turn back on
Is it plugged up or running on battery power? If it is on AC, try another socket instead of the one used now. If it doesn't turn on while connected to AC then it is likely defective and should be returned. But, just to double-check, try a new battery or a different charger and make sure it is securely plugged into the battery charging port.
May 23, 2014 | Verizon Wireless Jetpack 4G LTE Mobile...
Mi-fi vERIZON
This device will operate as intended with either of the power sources mentioned.
Apr 14, 2014 | ZTE Verizon Jetpack 4g/3g Mobile Hotspot...
My verizon jetpack keeps shutting off
It always helps to provide the Make and Model of Jetpack you are having issues with. Most Jetpacks have a reset button normally located under the back cover that you can hold down for 10 seconds with a paperclip to reset. You can also look at power management settings by logging into the admin page by typing 192.168.1.1 or my.jetpack in your address bar.
Feb 28, 2014 | Televison & Video
Got new Verizon jetpack today..have a d-link device...won't connect.....previous Verizon mi-fi worked fine????
Well, sorry to say you have struck out, first it's Verizon, then a JetPack and finally D-Link. The only way I was able to get mine working was to switch to a Cisco device for the link, drop the D-link!
Oct 24, 2013 | E-Machines eMachines Desktop PC
I accidentally block some of my contacts on my samsung corby2 can u help me to unblock
Have you been try the Coolmuster Data Recovery software? This software can help you recover your Samsung phone contacts at ease, you can have a try.
Read more: http://www.coolmuster.com/android/recover-photos-videos-from-galaxy-nexus.html
Sep 07, 2012 | Samsung GT S3850 Corby II
I need help unblocking the puk for mi at&t pay as you go mobile phone so i can get back to mi screen saver please. somehow i was trying activate my phone an accidentally pressed the wrong thing. once i...
that is your sim card. please contact your service provider for a replacement. puk once blocked, that it the end of your card. you loose everything on it but can have your number back from the provider.
regards
Jun 07, 2010 | AT&T Samsung a117 Pay-As-You-Go Cell Phone...
Verizon Wireless Jetpack 4G LTE Mobile Hotspot 890L Logo
69 people viewed this question
Top Verizon Wireless Computers & Internet Experts
Jerry Kramer
Jerry Kramer
Emory Griffis
Lesley Cameron
Lesley Cameron
Are you a Verizon Wireless Computer and Internet Expert? Answer questions, earn points and help others
