Question about KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range
To clarify my question about the thermal fuse on Kitchenaid KDRP467KSS. The fuse that I am needing to recoplace is in the front of the oven, next to the ntrol panel (not the fuse in the baarck). I removed the front panel, and can slide the control ti bod out a little bit. This fuse is right next to it, I can see it, but I can barely reach it. I tried a few times by just pulling, but I'm afraid I'm going to break it. Do I need a tool or is there a trick? Or do I just yank??? Thanks
4 Suggested Answers
  • 1314 Answers
SOURCE: kitchenaid kgri801pbs
there is a thermal fuse in the back of the oven that more than likely has tripped during self clean poor air flow around can cause this power surges during self clean can too you have to pull the oven out and remove back panel to find it
Posted on Jan 10, 2008
SOURCE: Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Posted on Jan 22, 2010
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Stove top works, no power on the oven. KDDT207A
I had the same problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Jan 04, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Kitchenaid oven kdrp467kss09 no elecrical power
Dec 31, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
I have the same problem as djeff757 post on Kitchenaid KDRP467
I don't recall a control panel fuse for this model, there is, however, a thermal cut-off on the rear of the unit. The part number is 8300802 and you simply have to remove the rear panel to access it.
Dec 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Gas oven does not work. electric upper element does work. codes
Dec 26, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
DOOR ON KDRP467 WO'NT OPEN
Replace the control panel thermal
fuse (Microtemp G4A01093C). Its in the wiring harness between
the control transformer and the control panel on a blue wire.
It looks like a resistor inside a clear plastic tube and is
mounted on a metal bracket with plastic clips. It has a spade
connection on each end. It can be accessed by removing
metal access panels from the back of the range and it
is in the area below the gas burner deck.
Dec 20, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Oven Doesn't Work
See my post on this subject.
lapwte
Dec 14, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Error Code F5 E5
The repair on this issue will be one of either of these parts.
It is a common issue with Kitchenaid wall ovens.
9759242 THERMAL FUSE/THERMOSTAT/THERMAL T.O.D.
W10175596 THERMAL OVEN FUSE/THERMOSTAT
Sep 05, 2008 | KitchenAid Architect Series KEBC107KSS...
KitchenAid KDRP467KSS Dual Fuel (Electric and Gas) Kitchen Range Logo
49 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
