Question about Garden
Where do I get an icon x3750 mower manual ? - Garden
2 Suggested Answers
  • 42663 Answers
SOURCE: I need a hand throttle for a x3750 lawm
get from e-bay or any mower shop
Posted on Sep 24, 2017
This unit has new plug and new petrol in other and will start and run for a few mlnites and then stops
If this unit has a fuel cup at the bottom of the carburetor remove it and clean and clean the fuel jet as well. I blow mine out with air pressure or take a fine wire and push through it but do not mess the holes up. It does not take very much dirt to stop the flow. Check your float in the carb as well as it may stick and won't let enough fuel into the carb to keep running. I would check the fuel bowl and jets first. That is most likely to be the problem. another possibility could be the filter in the gas tank at the end of the tube that runs to the carb.
Dec 11, 2016 | Garden
Location of choke on Rockwell X3750 mower
probably a fuel shut off. unless this is really old it is not a choke
Sep 25, 2016 | Garden
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor ยท Operation Manual.โ€ŽCraftsman Lawn Mower manuals - โ€ŽCraftsman 247.370310 - โ€ŽCraftsman 247.37030
Aug 02, 2015 | Craftsman Garden
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
Hard to start Icon X3750
make sure your getting the three main things, 1. fuel 2. air 3. fire. if your getting those then something as simple as cleaning the carb/throttle body or new fuel or a new air filter
Sep 05, 2013 | Garden
Have a Craftsman No. 71-79717 200 MPH gasoline blower vac. Do not have operating instructions. Can you help?
This should be your model number:
358797170
On the right side of this link:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Leaf-blower-Parts/Model-358797170/0247/1503120?searchedModel=79717&blt=
Click on "get manuals" then next page "view manual"
This page should be displayed:
http://www.managemylife.com/mmh/owner_manuals/26375/CRAFTSMAN-Blower-Gas-L0520190?brand_name_search=358797170+CRAFTSMAN
Once the manual is downloaded to the screen there is a save file option on the tool bar at the top of the document. (2nd icon from left)
Thanks for choosing FixYa.
Kelly
Nov 15, 2010 | Garden
I need a diagram for installing a deck belt on a 42' Craftsman Mod.#917259330
You can download the User Manual here from ManageMyHome,
http://www.managemyhome.com/mmh/owner_manuals/search?query=Craftsman+917259330&find=
(Just copy, and paste the above into your address bar, then press the Enter key)
On this page where it has Go in the blue square, go below that, and click on -> View Manual.
This is a PDF file download. Took me about 12 seconds to see the first page, (I have Medium speed DSL )
Page 22, (Service and Adjustments), starts showing the routing of the belts.
The deck belt makes a T shape. It goes around the two mower blade pulleys, (Mandrel Pulley), and then around the engine shaft pulley. There is a tension pulley is on the left side, it's on the outside of the belt, and pushes IN on the belt. There is a tension pulley on the right side. It's on the outside of the belt, and pushes IN. (Pushes in. Pushes towards the center of the mower)
The Motion Drive belt goes around the rear end pulley, (Transaxle Pulley),
goes up the left side of the mower, to a pulley that is mounted solid to the deck, (Stationary Pulley), comes to the inside of that pulley, then goes to the outside of the Clutching Pulley, up around the engine shaft pulley.
From there, it comes back along the right side, to all the way to the Transaxle Pulley.
Should you wish to save a copy of the above manual, it's easy. In the header bar at the top of the PDF file is a Floppy Disk icon. It's the second icon from the left. Hovering your mouse cursor on it, will briefly reveal,
"Click to save this file to your computer or another location"
You will then see a ->Save a copy:, small window come up.
At the bottom of this window is the Filename:, box.
Put your mouse cursor in the box right after the -> f, in .pdf
Left-click Twice. Make 1 space with your spacebar. Now type ->
Craftsman 42 inch Mower Manual. Then go to the bottom right of the window, and click on -> Save.
If you do not have your downloads set to download to your My Documents folder, this will go to your desktop screen. In any event, just double-click on it to open it. You can also burn a copy off to a CD.
(If you do not type Craftsman 42 inch Mower Manual, or something you will recognize later, you will be going around looking for ->L0901538.pdf)
Jul 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
CMM1200
see www.dewaltservicenet.com. look for find it now icon
enter the model # & search
Jul 22, 2008 | Black & Decker 19" Electric Lawnhog...
How do I replace the saw on the black and decker navigator handsaw
manuals are available at www.dewaltservicenet.com looks for
icon find it now.enter the model on the box & search
Jul 04, 2008 | Black & Decker 19" Electric Lawnhog...
Need Parts for MM575 Type 1 Electric Mower
www.dewaltservicenet.com for parts & breakdowns all the cost of the part. just look for icon find it now & enter the model.
hope it helps
Jun 20, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
