Question about GE WBSE3120B Top Load Washer
Washing machine relay fuse - GE WBSE3120B Top Load Washer
Do a aquarius washing machine got an internal fuse ?
no internal fuse circuits relays and switches --your breaker turns off the units power when problems with electrical
Oct 16, 2016 | Washing Machines
Washng machine
Code 54 is the motor relay contacts are sticking.
Dec 28, 2012 | Washing Machines
F-05 MESSAGE HAS COME UP ON MACHINE WHAT DOES THIS MEAN?
hi have a look below hope this helps, then goggle how to fix it!
Sep 06, 2011 | Hotpoint Aquarius WD640 Front Load...
Vw passat 1991 electric windows will not work have checked all fuses. Is there a relay and if so where?
Certainly not in the washing machine ;-0) Sorry but you have posted to the wrong Forum. Good luck with the correct one. John C
Jul 08, 2011 | Washing Machines
My washing machine will not agitate. It spins and drains. The manual says it could be a fuse. Is that correct?
No. not a fuse problem
This is a problem, with your timer switching. If it is electronic check with new one. Check associated relays also.
Mar 28, 2010 | Washing Machines
No heat
Check on the back of the drum for a thermal fuse or relay. Common fault on tubledryers is no power to heating coils becuse of blown fuse or most likely the relay to heating coils is dirty. have to be cleaned about every 2/3 years depending on use.
Aug 09, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
My maytag performa washing machine blows fuses/trips breakers
there must be a shorted wire or a burn capacitor. You will have to trace the wiring to see if there is any broke or loose wires or solder joints or burn marks on the circuit boards. You can also test relays with an ohmmeter or multi-meter to make sure there is resistance.
Jul 09, 2009 | Washing Machines
Have a wjrr417og1ww washing machine. it is about
if ther was a power surge or power went out machine needs to be reset unplug for 1 minute then replug unit in and open lid 6 times in 12 seconds it should reset . that is what i had to do with mine
Jun 15, 2009 | General Electric WJRR4170GWW Top Load...
Stops between cycles
sounds like a bad motor control board. It is located at the front rt bottom and will probably show a burnt spot in it or the fuse will be blown. You must replace motor kit.
Jan 05, 2008 | Maytag Neptune Washer
GE WBSE3120B Top Load Washer Logo
16 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
