Question about RCA HD52W58 52" TV
Multi-color double images or shadows and curved screen
I have a RCA model number HD52W59 52" and it has multicolor double images or shadows plus screen is curved and not reaching screen edge
  • pennyjk2005 May 18, 2009
    Thanks for the reply someone on another site told me to replace the flyback fuse. They did not mention the other board. Do you think replacing the one fuse will fix it alone? Or will I need to replace them all?
  • 39 Answers
Alrighty, very common problem on this set. Here's a rundown of the repair if you're a DYI:
With the back cover off you'll notice a set of boards on the bottom of the TV and a pair of boards sitting up over the two bottom boards. The problem lies in the upper-right hand board which is the color convergence power supply. Either replace or repair this board. The repair involves the main power mosfet (a three legged regulator on a heat sink) and two diodes next to it.
Next, the bottom right hand board needs to be removed and a fuse replaced next to the flyback. If you are versed in electronics I can detail the repair further otherwise you're going to have to have a shop do the repair.
Posted on May 18, 2009
  • Justin Rubsam
    Justin Rubsam May 26, 2009
    I find that 90$ of the time the fuse fails due to a faulty convergence power supply. The other 10% of the time the fuse fails because of a bad solder joint on an adjoining flyback leg. Change the fuse and see, worst that can happen if you have a bad convergence p/s is that it will blow again. Then you'll know!
My RCA Model number HD52W59 has color distortion and double image and sunk picture in the middle. Is there any way of fixing this problem. This tv is a projection TV
Yes.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 08, 2010 | RCA HD52W58 52" TV
The screen has a double image and also has a
u have bad convergence , this is a problem from the deflection board , the repair of this repair is about $250
Apr 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
RCA D52W26. Yesterday the TV all of a sudden started to give Color shadows and then it curve the image.
Easy, repalceing two covergance chips
fixes the problem . the chip cost 10.00-20.00
etch , dont pay more than 175.00 to
have a shop fix it
Jun 28, 2009 | RCA D52W23 52" HDTV CRT TV
Rca color problem
does the convergence option still appear in the on screen menu or has it disappeared? Let me know and I will assist you
May 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Shadows and text curved. Double images
The convergence IC's need to be replaced. The generic part # on them is STK392-110. This is not easily done by yourself.
Apr 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Rca 52 hdtv
I would need the model number of your RCA in order to help you, please respond to this post so I can have your symptoms in front of me when you post your model. Also can you adjust it through the convergence menu?
Jun 25, 2008 | RCA Televison & Video
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
RCA HD52W58 52" TV Logo
439 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
