Syntek code H1 on syntek air conditioner
How to remove H1 error in voltas AC?
It indicates a problem, what that is contained in the factory repair manual and meant for technicians. when the error has been been repaired the code will clear.
Apr 20, 2016 | Heating & Cooling
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
Amana air condicioner code error h1
high limit switch. in heat mode check indoor coil and filter. in cooling check outdoor fan and coil.
Jan 26, 2014 | Heating & Cooling
Voltas ac vertis premium showing H1 Indication?
Voltas vertis premium display showing "en"
May 05, 2013 | Heating & Cooling
Lennox 8 series ms8-z0-2ap3a error code H1, defrost operation
h1: defrosting /normal operation/ normal defrost operation.
see more: Air Conditioning Fault Codes
Jan 16, 2013 | Lennox Heating & Cooling
What means h1
H-1. High pressure switch open. Check gas pressure/clean condenser coil/Check fan motor speed/Replace capacitor for defective.
Dec 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
When i switch on my ac it enters into h1 mode and i dont how to get out of this
from inside the cover have a restar button trye whit that
May 20, 2010 | Heating & Cooling
Amana PTAC ptc093d35ar, when i switch to remote t-stat i get a H1 code in the display. Can you help??? Joe
H1=High voltage protection engaged. Power supply voltage is too high. Check for incoming power at correct voltage.
Jan 20, 2009 | Amana PTC093B35AE Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
