Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
Bottom plate wont come off
I removed the 5 screws off the bottom plate but it wont come off the top cover so I can replace the belt.
  • 34 Answers
There are hidden release latches use a thin blade between the two plates
Posted on Dec 27, 2013
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
Hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
Apr 18, 2010 | Vacuums
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
How to install a U8172-900 belt
your savvy bagless has a geared belt. remove the bottom plate and then remove the 2 back screws near the back wheels to remove the top cover also peel off the hoover decal to access the top cover screw. this will expose all components to replace the belt.
Sep 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Jan 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How do you replace the belt on a Hoover Savvy?
Take off the bottom plate, then remove the screws to remove the top cover, turn vac over, remove the hoover emblem, there is a screw there to remove. The top should come off, the easiest is to loosen the motor to give you some slack, then replace the belt and reasemble.
Sep 04, 2008 | Vacuums
Changing the belt
If this is a Savvy, then take out the screws for the bottom plate, then remove the screws that hold the top on, turn the vac over, and remove the Hovver emblem, there is a screw there, then the top cover comes off and you can replace the cogged belt.
May 31, 2008 | Hoover U8185-900 Upright Vacuum
Belt broke on my model u5064-940 and need to replace it
Remove the bottom plate, then use a flat blade, from the bottom edge of the top cover, pry out to release the tabs and the top cover will come off( there maybe 2 screws form the bottom to remove). Then you can replace the belt.
May 19, 2008 | Hoover Vacuums
Replace belt
On the bottom, there should be a few screws to remove to remove the plate covering the brush roll. However some may have screws on the top housing to remove the top.
Jan 06, 2008 | Vacuums
Changing belt on hoover runabout
Found this info on the web...haven't tried it yet
Sep 07, 2007 | Vacuums
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
261 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
