Question about GE Profile PDS22SBSRSS
Refrigerator stoped cooling but not the freezer
The refrigerator stopped cooling a few days ago but the freezer still is working. I think it could be the evaporator fan but not sure and don't know how to check.
  • Karim Hallal
    Karim Hallal Dec 28, 2013
    there is a repetitive sound (not usual) that comes out of the inside of the refrigerator box.
  • Karim Hallal
    I unpluggeg the refrigerator for 24H, but it still does not work :(
huuum
  • 750 Answers
SOURCE: whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Huuum
Please remember to leave a rating for me!
Posted on Oct 08, 2008
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: Not cooling, unpluged for few hours, it worked fro couple of weeks, stopped cooling again 2 days ago, I unplugged for few hours, It is working now
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
Posted on May 26, 2009
SOURCE: ge side by side not cooling
it could be two things your compressor is shot .check what date you bought it if less than one year you call the store you got it from or G.E but the store you got from sholud replace with a new one dont let them send a service tech out
Posted on May 29, 2009
Bottom freezer works great top ref stopped working a few days ago
The cooling coil (evaporator), located in the freezer is probably blocked with ice due to a failure in the auto defrost circuit of the unit.
Jan 15, 2015 | Maytag Refrigerators
How to replace defrost timer
a bad defrost timer can be checked with a multi meter
Sep 08, 2014 | Whirlpool Refrigerators
Refrigerator stopped cooling 2 days ago. Freezer works fine. What is broken? Appliance is four years old. Replaced compressor almost exactly 1 year ago.
Check the fan in the freezer and be sure it's working, isn't blocked by product or isn't clogged with ice. If this fan isn't working the refrigerator section won't cool properly.
Jul 18, 2010 | Maytag Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
GE Profile PDS22SBSRSS Logo
55 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
