Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
Dirt devil shampooer water not coming out
When I hold down the handle for the water to come out nothing happens. It is still sucking up dirty water but no clean water is coming out.
KOakaKO
  • 135 Answers
SOURCE: Ok, perhaps I am an idiot!
If you go to this URL: http://www.dirtdevil.com/CustomerService/Manuals/default.aspx ...and enter the model number for your machine, then you can download a users manual. I would just give you the exact URL for the user manual, but I don't know your model number. If this helpful to you, please leave a good rating. Thank you! ;)
Posted on Aug 13, 2007
reddevil6
  • 1673 Answers
SOURCE: wet vacuum not sucking up water
Usually when these units don't pick up the water, there is a seal or gasket missing or out of place. But you have a years warranty on this, maybe you should take it to a warrenty shop and have it checked.
Posted on Jan 29, 2008
maklean
  • 1665 Answers
SOURCE: i have a dirt devil
hi Have anice day!
see your machine layout and parts here
(Click any NUMBERED Part )
Posted on Mar 11, 2008
galati2k
  • 281 Answers
SOURCE: Dirt Devil Vision bagless not working
make sure your brush roller is turning.unplug the vacuum and see if you can turn the brush roller by hand.if it turns real freely then your belt is more than likely broke
Posted on Apr 09, 2009
luckyluke78
  • 333 Answers
SOURCE: dirt devil shampooer won't pick up any water
you can download the manual free from this link,and go to trouble shooting on page 11
http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=8fac8b06-4ad7-49a7-ac82-6f608a77a3bb
Please leave positive feedback if I have helped you
Thankyou
Posted on Aug 09, 2009
Why doesn't my dirt devil vision turbo have any suction through the hose yet there's good suction at the hose connection to the canister?
The hose is probably blocked. If possible reverse it (put the intake of the hose on the canister connection) that should suck out the obstruction. If that fails try to carefully push a broom handle into the hose, preferably from the end that connects to the canister. Put the hose back on normally and see what happens.
May 22, 2015 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt devil spot scrubber not picking up
Hi there! There are a few reasons why your spot scrubber may not be picking up. Your dirty water tank may not be seated properly or the filter may be dirty Please try these steps.
1. Check the filter located on top of the dirty water tank. If dirty, rinse with water.
2. Check that the pour spout cap on dirty water tank is plugged.
3. Replace the dirty water tank. Make sure the dirty water tank is flush to the cleaner and seated properly.
4. Clean the nozzle of any hair or debris.
Hope this helps! For further assistance please feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Jul 03, 2014 | Dirt Devil SE2800 Spot Scrubber Handheld...
When I step on the head so that vaccum enguages it stops sucking. You no longer hear air being sucked through the handle as well, the head does not **** down to the floor. When you lock the handle in the...
near the bottom of the vacume where the hose bends down to the floor sweeper, check to make sure there is no blockage. this is the most common problem with vacume suction. you can use a wire coat hanger to help loosen the dirt and debris from the line and it is sometimes easier to clean properly if you remove the bottom plate ( like you would if you were changing the belt ). also while you are getting dirty and having fun, this is a good time to clean the air filter, ( tap it out good or/and use a brush or air compressor to clear and clean ).
c...
Dec 31, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction
open the tank where dirty water goes and make sure the float is down and not stuck ...when its full of dirty water the float raises with the water level so that the vacuum doesnt keep sucking and overflow
Jan 03, 2010 | Dirt Devil CE5500 Floor Keeper Upright...
My dirt devil is not sucking,i cleaned out hoses and bottom seems to be turning fine?
The fan motor is probably not working. Does it sound normal? Higher or lower pitch sound?
Dec 05, 2009 | Dirt Devil Vacuums
I have never used a shampooer before when I use it it says to empty out dirty water. I don't have any left. My tank is empty. Am I doing something wrong.
Suggest that you do the following.
Remove the TOP ("Clean water") tank. Fill it 1/2 full of water. Put the top on the clean water tank and place it back on the machine.
Release the machine handle and remove the cover of the "dirty" water tank. Inspect the back of the tank to be sure that the vacuum adapter in located in the rear of the dirty water tank. If not-that is your problem. If yes, restore the top to the dirty water tank.
Power the machine on.
On a kitchen floor, power the machine on. Pull the trigger and hold it for about 30 seconds. You should see water gathering around the brushes. If not, that is a problem.
With water around the brushes, release and lower the handle and and move the machine over the water. It should vacuum the water into the dirty water tank.
Is all of that happening?
Nov 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dirt Devil Featherlite carpet shampooer won't release solution
Had the same problem only after 2 uses, called the 1 800# said that soap may have "gummed" up the line did everything they said but didn't work. Would cost more in service repair if I could find a authorized dealer to fix than I paid for the machine. Would not recommend this machine to anyone.
Jun 10, 2009 | Dirt Devil CE6100 Featherlite Upright...
I don't see the dirty water re-entering the tank to dump.
your suction tube where the water gets sucked up is clogged
May 03, 2009 | Vacuums
Cleaner not sucking up dirty water.
try stripping it down and cleaning all parts and filters .some cleaners use a safety 'ball' to stop water getting on the motor is this stuck it should slide up and down a small track in a tube..good luck hope this helps farr64.
Apr 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
