Question about Dell ST2010 20 inch LCD Monitor
Monitor went dim - Dell ST2010 20 inch LCD Monitor
Monitor Flashes Then Goes Very Dim
Check and replace the inflated capacitors on the power/invertor board. The generated 12 volts are unstable and protection cirquit turns the invertors off to avoid damage to the IC
May 16, 2015 | HP 2311x 23-Inch LED Monitor - Black
Half of the monitor screen went dim
Faulty screen? Try an external monitor to prove it.
Apr 08, 2015 | HP ProBook 6440b Notebook
Samsung 21.5 LCD monitor suddenly turned dark. Can this be fixed or should I just trash it?
Your monitor has symptoms of power supply failure. The age of the monitor and the cost of repair will influence your decision whether to repair it or dump it
Feb 25, 2013 | Computers & Internet
Video went dim and bright and then stoped
try to check if the cable connected to your monitor is connected properly. Try to tighten the screws and locks but dont force it too much. Then Turn off the monitor and turn it on. If problem still continues,
try to check the monitor in other computers if it works fine, then the problem will be on your computer, or the power lines of your house, check if the current is good. If its then maybe
there may be a problem with the connector. Try to change it if you can.
If problem still continues then maybe theres a problem with the power circuits of your monitor.
Hope this will help you out.
Pm me if you still have that problem, i will provide more solutions.
Aug 08, 2009 | Computers & Internet
Dim and flicking last black screen
It sounds like your monitor went bad. It happens. Call around. There are a lot of deals now. Good luck.
Aug 04, 2009 | ViewSonic VX1940w LCD Monitor
Computer Monitor is dim
Time for a new flat screen monitor...The power supply is on it's last legs.
Apr 03, 2009 | Toshiba Tekbright 15" CRT Monitor
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
The brightness and color have dimmed.
This could be something with the cable or an internal connection if it is intermittent.
Mar 02, 2009 | E-Machines eMachines Monitor E15T4
After working perfect it just went dim
See the existing topic 'monitor_barely_readable_dark_but_display'.
Jan 26, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
Dell ST2010 20 inch LCD Monitor Logo
Alun Cox
