Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
Need to remove bottom plate to change belt
Took out the 5 screws on bottom, but plate wont come off.
  • Euro-Pro Master
  • 18,402 Answers
How to remove the belt
Most vaccumeing have 4 to 5 screws holding the bottom plate remove plate pull out roller . Slide it off the roller and motor replace with new belt by first slide belt around motor arm then roller pull roller into place then roll the roller 3-4 times to insure it's in the right spot. Replace bottom plate
Apr 11, 2015 | Vacuums
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
Bottom plate wont come off
there are hidden release latches use a thin blade between the two plates
Dec 26, 2013 | Euro-Pro NV22 Shark Navigator Bagless...
I need to know how to change the belt on a fantom xt
Turn it upside down.On the bottom where the brush is are 4 screws.Unscrew those 4 screws.Remove the plate.Now you can see the belt.There may be a second plate covering part of the belt,if so remove it too.The belt fits around the brush in a groove the same width as the belt.The other end of the belt fits on a small wheel about half way back from the brush.Put the plate back on and you are done.
May 14, 2011 | Vacuums
Can not change belt
some of the eurekas ha screws on the top of the base to remove the cover.others have the screws on the bottom.if they are on the bottom there will be 5 screws1 on each en of the roller in front and 2 on each end of the roller behind the brush and 1on the rear of the bottom plate where yo can see where the belt guide is.make sure you clean the old rubber off the motor shaft or your new belt won't last
Apr 23, 2009 | Vacuums
I Need to change the belt on hooverwhirlwind
there should be 4 screws on the bottomsome have little flat snap that secure the bottom cover on.push the snaps toward the outside of the base and the cover should come off.if they are screws just remove the screws and take off the bottom plate.then you will be at the belt and roller.be sure to clean the old rubber off the motor shaft before you put the new belt on.otherwise the new belt won't last long
Apr 10, 2009 | Vacuums
I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
I can't figure out how to change the belt on my hoover bagless Sprint upright. Please help.
1 set up vacume with bottom facing you , making it easy to deal with.
2 remove the 4 screws holding base plate on and carefully remove the base plate, on mine there is a small catch that must be released.
3the belt compartment is on the right, remove the old belt, it's about 1 and 1/4 wide.
4 You have to put the belt on the stainless steel motor spindle first, then work the belt over the plastic drive wheel, and spin it around a few time to ensure it's running on track ok.
5 Replace the base plate , click in the self catching clip last.
6 Replace the four screws and test the vacume.
Oct 23, 2008 | Hoover Vacuums
No belt
There are two screws on the top side just behind the Brush housing. Remove these two screws, one on each side, and the top plate can be removed. Then you can follow the directions above.
Hope that helps.
Apr 21, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
88 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
