Show how to change roll of tape in a 1610-03 dymo organizer
4 Suggested Answers
SOURCE: OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Posted on Jul 09, 2009
SOURCE: Problem feeding 9m tape in Dymo 1895
I have one of these and there is a white sliding button on one of the broad sides of the labelmaker. It slides from 3/8 inch to 1/4 inch. It is located toward the top right. It's NOT the side with the letter wheel but the opposite side. If yours doesn't have t his button, it probably won't take two sizes of tape. (But I'd be surprised if it didn't have the button.) Hope you find it.
Posted on Sep 01, 2010
rohntech
  • 422 Answers
SOURCE: Letratag showing tape jam. Have
there's a paper jam inside the mechanism of thermal label printer, if you can do open it, clean it also, just be careful to put it again.
Posted on Feb 12, 2011
My Dymo 210D will not feed the tape. The little dealy thing goes around, but the tape doesn't feed.
My works Dymo LabelMANAGER 210D broke down because of a weak construction. The tape cartridge door pulls via a spring the print head towards the roller. Its plastic lever couldn't handle the strain. I repaired it with a peace of locking wire, as you can see on the picture. Greetzzzzz Arno
Aug 29, 2013 | Dymo LabelMANAGER 210D - Labelmaker - B/W...
Cleaning instructions dymo letratag
Remove the cassette and moisten the supplied brush with some alcohol solution. Rub the print head to clean it. Make sure there is no tape wound round the rubber roll.
Feb 22, 2012 | Dymo LetraTag QX50 Thermal Label Printer
I am trying to load a new roll of labeling tape into the Dymo Organizer 1610. But the tape doesn't advance properly into the front part of the machine that does the printing.
Before inserting the tape into the feed mechanism, bend the last 1/8 inch of the tape upward at a slight angle. This will insure that the tape feeds properly. I just learned this by trial and error.
Aug 03, 2011 | Office Equipment & Supplies
When i select print I hear it running but label does not move. I changed batteries and I cleaned roller. Is the piece across from the roller suppose to move to guide the label thru?
The rubber roll is supposed to do it. Since it is clean, pull out some tape and try again. Otherwise, please contact our help desk. The numbers are at dymo.com.
Apr 09, 2011 | Dymo LetraTag QX50 Thermal Label Printer
Letratag showing tape jam. Have changed batteries and tape roll
Feb 12, 2011 | Dymo LetraTAG Thermal Label Printer
Hi I'm wondering if the Dymo pocket will take a tape, so that I can iron labels on to clothing or even be stitched on. If so what would the cassette be called. Thanks
The Dymo label printer capable of printing iron on tape is the Dymo Letratag. There are a couple of model printers
Dymo Letratag - handheld model
Dymo Letratag - desktop model with qwerty keyboard
and the Dymo 18771 Letratag iron on tape is the tape cartridge available.
Jan 21, 2010 | Dymo LabelPOINT 100 Thermal Printer
Error 1 message
Check the batteries and that there is nothing clogging up the tape area. Any little bit of tape can cause the error message to come up. Also if you put in say 4 new batteries and kept 2 older ones that show a little life still left, can cause the error message. Change all the batteries at the same time.
May 07, 2009 | Dymo LetraTAG Thermal Label Printer
How to load tape
it's not obvious indeed!
The idea is to;
1. take out the ring (try it by releasing the back part first! easy does it.
2. put tape into the Dymo 1855 mk II by pressing the white lever down
3. then take the tape you pushed through and guide it through the ring.
4. Put the ring back into the Dymo.
It worked for me ;-)
Good luck,
Marc
Nov 16, 2008 | Office Equipment & Supplies
19 people viewed this question
jasbo
jasbo
