Question about Sharp INKJET FAX UX-A1000
Missing part of page
When I fax or copy a page, the top 2" is missing on the copy/fax received on the other end. I cleaned the rollers, but that didn't help.
Erin
  • Hgyt Dec 29, 2008
    Part of the page is missing when I'm faxing or copying - 2" top of the page ???
    I have Sharp Fax Machine Model - UX-A1000.
    ANY HELP ????????????
    Thank You
  • 121 Answers
I would go through the menu till you maintence ,then find system restore and press yes or print to execute.This will put it back to factory specs.If that does not help you probably have a bad stepping motor.
Posted on Oct 18, 2007
I get plain paper or double when I received fax from my uf5300 laser fax.it print one page from 5 pages that sent and I got empty pages and double somtimes
Paper feed rollers and sheet feed pad dirty. Feed roller on top pad should be just below. Clean with alcohol. Papers have clay in them. Recycled is worst. It will glaze the pick up roller and pad.
Sep 21, 2014 | Panasonic PanaFax UF-8000 Laser Fax
I using a roller fax machine. today i had fax a documents that have 4 pages and i put together and let it run auto. i confirmed that i fax once only but the receiver received the first page more than 10...
By "roller fax" if you mean auto document feeder, so what's the problem? If you didn't see each of the 4 pages feed into the machine one at a time then what happened at the other end could be because something happened at your end. It's the reason we scan and email most critical documents today.
Carl
Apr 14, 2011 | Office Equipment & Supplies
Hp 1010 fax- Receiving end has an area approx 4" header that is blank and moves the document to 2 pages. Happens on my end when I copy.
adf rollers need to be replaced the doc is late going in to the adf that is why it has a header of blank thanks quikship
Nov 05, 2009 | HP 1010 Plain Paper Inkjet Fax
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
Paper sticking together when receiving a fax
There is a separation pad under the feed roller,that pad needs to be cleaned or replaced.If you open the fax and remove the cartridge,inside at the back were the cartidge was you will find a roller,cleen that roller.Under the roller there is a strip of rubber-the separation pad.Take a ruller cover it with a cloth and use it to clean the sep assembly under the roller.If the problem pressist the sepparation needs to be replaced.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Problem with page cut-off
See pages 92 of the manual to "rotate the white roller"
The procedure rotates the roller a quarter turn each time.
You might have to repeat it a few times in order for thit to be set at the right position.
I tested mine using the copy function as well as a TEST FAX to a another fax machine.
Good luck!!
May 29, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp INKJET FAX UX-A1000 Logo
148 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
