Question about Technics SL-MC50 CD Player
Technics sl mc50
The error message "ERROR" appears on the display, and the changer stops operating. The machine is well-kept and never gave us a problem before. I tried unplugging it several times, but no luck. Any suggestions?
  • 6 Answers
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Posted on Mar 01, 2009
SOURCE: Looking for a drive belt
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Posted on May 21, 2009
donnydo77
SOURCE: technic sl-mc7 110-disc cd changer
The problem is likely the carriage drive belt. The player is well over 10 years old so the belt gets stretched with use. Then it is unable to transfer power for moving mechanisms.
If you feel comfortable about opening the cover using proper electrical safety procedures then you can observe what the carriage is doing upon turn on. Unplug the player, remove the cover by unscrewing four fasteners (I think, but you can easily figure it out), plug in and power up. The carriage should go through a positioning calibration and disk checking sequence (simply, it moves out of the home position, travels across the player and repositions itself to await front panel input).
Yours probably doesn't so look at the belt on the top of the carriage. If it is off the drive wheels, remove electrical power, then simply put it back on, power up, and recheck.
If the belt is spinning on the wheels and seems loose then it needs replaced. Fortunately, here is an inexpensive and attainable replacement courtesy of another FixYa poster
http://www.fixya.com/support/t1616894-looking_drive_belt
Also, a clean up and lube of the mechanisms would be a good thing to do. That takes some technical know how to clean without damaging and applying the correct lube in the right amounts to the appropriate mechanism components. Some general references are available in electronic service books or online. I should probably launch a site!
Otherwise, without knowing the conditon of other components in the drive assemply, a service manual is required to proceed with further troubleshooting specifically for the player.
Hope that the K.I.S.S. approach helps you enjoy your player again.
Posted on Aug 06, 2009
SOURCE: My Technics SL-DZ1200 will not play certain MP3
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Posted on Nov 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: i need to download a users manual for technics
Web search "Technics SL-MC3 manual" and this pops up...
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/How-To-Guides/model.SL-MC3.H
Please try the search engines first.
Posted on Aug 08, 2011
Brother sewing machine ce1100prw error 1
This link from Brother Support :
An E1 message appears on the panel Brother
But another reference indicated E1 results from some operation being performed incorrectly.
To fix .... lower the presser foot lever before continuing operation. If the error message has not disappeared, press the stitch selection key while the error message is displayed.
Mar 16, 2018 | Washing Machines
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won't work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
Eh0 error message during operation
need manual or need to know if washer starts and when it stops as this can identifie the problem
Aug 12, 2012 | Zanussi Washing Machines
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
As soon as the machine is on an error message of 3E appears and the machine stops
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 14, 2010 | Samsung WF337AA Front Load Washer
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
Monsoon Radio CD CHANGER ERROR
CHANGEUR CD ERROR . g6 2006
Jan 14, 2009 | 2003 Hyundai Santa Fe
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Dec 21, 2008 | Car Audio & Video
Error message
got the smae problem gc 02. error msg in display..any tips?
Oct 26, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Technics SL-MC50 CD Player Logo
121 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
