Question about Pioneer GM-7300M Car Audio Amplifier
I got a 800 watt amp from my friend and he didnt have instruction
I wanted to know if anyone can tell me where i can get instructions for this amp or if they can tell me how to take the treble out of the subs and leave me with more bass.
  • 1 more comment
  • Millionaire3 May 18, 2009
    its a pioneer gm-7300m could be wrong but im pretty sure thats it cause it looks exactly like it
  • Millionaire3 May 19, 2009
    hey what is the Speaker Input feature on the amp? and how would i use it?
    ok got you
  • 221 Answers
What's the exact model of your amp? For taking the higher frequencies/treble out of the subwoofer, the amp should have a little button on the side that says "Hi Pass" or "Low Pass" or maybe an adjustable knob-thing that says "X-Over". These will set a cut-off frequency for your sub output. Some amps don't have this feature, but many do.
Posted on May 18, 2009
  • Sphynkter
    Sphynkter May 18, 2009
    You can find the owner's manual for your amp here:
    http://pioneerusa.com/pio/pe/images/port...
    On page 1 of the manual, it displays the location of the Low-Pass filter for your sub control. THis is how you would cut the treble out of your sub and get more bass. Bass Bass. Rock on with your bad self...
  • Sphynkter
    Sphynkter May 19, 2009
    The Speaker Input on your amp is used only when you don't have RCA outputs from your head unit. Speaker-level inputs are the backup-plan. If your head unit has RCA outputs, and your amp has RCA inputs, that's all you should use. The Speaker Input is used when no RCA cables are available. In this case, you would steal the speaker wires from (for example) the rear deck speakers in the car, and feed them into the amp. The amp would then take speaker wire, convert it to a usable signal, and then amplify that. You shouldn't use this feature if you have RCA cables from the head unit.
I have a pioneer ts-w304r 12" subwoofer with a Dual Xpr520 400 watt amp, and a kenwood kdc-bt742u head unit. everything is hooked up properly. i know for a fact, and the head unit has all subwoofer options...
bad sub or amp. test your sub with a 9-12 volt battery not a car battery!!! more like a drill battery with low amp rating (don't leave power to it very long or could wreck your sub coil). if that work. then test your amp with a working output if you have a friend with a system hook it up in there car to see if it will work. pawn shops test amps tell them you want to sell it and they will test it and then decline their offer. lol just thought of that on the spot.
Mar 11, 2015 | Pioneer Car Audio & Video
I want to no wat this parts number is Q4025p for a peavey cs 800
2 Channel Peavey CS-800 Amp (800 Watts) ... Peavey CS-800x 800 Watt PA Stereo power Amplifier. The Part in question Q4025P is an alternistor. Two SCRs back to back that may have shorted out if it is not working.
Apr 11, 2012 | Peavey Audio Players & Recorders
Given 1hp motor how to compute the exact amount of amphere use in circuit breaker
You're not going to be able to do this with just a known Horse Power.
There are 3 elements to the equation, with any two, you can work out the third.
If you want to know how the amperage, you will need to know the voltage and wattage of the motor. I imagine that you already know the voltage (It's going to be 220V or 110 volt)
Watts divided by volts = Amps
Examples:
A 220v 1000 watt motor (1000 divided by 220) will draw 4.55 amps
A 110v 800 watt motor (800 divided by 110) will draw 7.27 amps
Bear in mind that most washing machines have a couple of windings for wash and spin. As an average, the was winding will usually be about 500 watts to spin and about 250 watts to wash. ALSO, bear in mind that if you are using this data for a WASHING MACHINE, then there is a water heating element in there too and that draws about 2Kw (2000 watts)
Dont just take this as read, you DO need to check wattages, but, working on what I have just said, the max consumption on a 220V machine will look like this:
At Spin, with a 500 Watt consumption: (500/220) = 2.3 amps
While Washing with a 250 watt consumption: (250/220) = 1.14 amps
Consider that the WASH and HEAT may be running at the same time.
2Kw heating (2000/220) = 9.1 amps PLUS 1.14 amps for the motor - Total wattage 10.24 amps
Watts / Volts = Amps
Amps x Volts = Watts
Watts divided by amps = Volts
Aug 25, 2011 | Washing Machines
BRINKS 42-1014 OUTDOOR ANALOG TIMER
I don't have an instruction manual but there's not much to know. Set the on/off times by depressing the white and grey tabs just above the hour notation for the times you want. If the tabs are up then the power is off. If they are pressed in then power's on. Plug it in, turn the dial to the current time and attach a device using less than 500 watts and you're good to go. There is a # to the helpdesk 800-562-5625_36.jpg
May 06, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Sony X-Plode amplifier. NOT working
It is possible if the model amp you have is bridgable to 1 channel. Usually when you bridge an amp you will need to hook one wire to the positive side of one channel and the negative side to the other. You will need to consult you user manual for the amp or get the manual from the sony website for instructions on how to bridge the amp or if the amp is even bridgable.
Oct 11, 2009 | Car Audio & Video
I wonder if anyone knows where I can get some operating instructions for a Jessops astranomical telescope 800-80? My partners son bought one from ebay and it didnt have any instructions so doesnt know how...
You will not find a manual for this telescope. However Meade maintains a web site for their telescopes find one similar to yours under the REFRACTOR heading on this page:
http://www.meade.com/manuals/index.html
Sep 01, 2009 | Optics
Need instructions
most amps are self explanatory just look at the outside edges where the wires go into the amp and they are usually printed positive remote negative and so on with the speakers
Apr 05, 2009 | Car Audio & Video
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
Cleaning instructions
Try this. It works for the Stainless Steel juicer as well:
http://www.dooyoo.co.uk/juicer/jack-la-lannes-power-juicer/1055142/
Jul 31, 2008 | Jack Lalanne Power Juicer 250 Watts
Will this amp push my speakers
Whoa, I do belive your rating for your speakers are inflated. I have never heard of a 6X9 accepting 800 watts thats just rediculas, its more than my 12" sub needs. Anyways, if this amp is anywhere from 300 to 500 RMS watts you will be fine. Because the speakers are small they need very little wattage to reach there potential, usually less than 100 Watts each, and probably around 50. If you think about it most decks put out 50Watts max for each channel, because that is the max you can assume that the RMS wattage of the unit is only around 20-25 Watts of power per speaker.
Mar 25, 2007 | AudioBahn A4401Q Car Audio Amplifier
Pioneer GM-7300M Car Audio Amplifier Logo
139 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
