Question about Compaq Presario 5686 (402445-003) PC Desktop
BIOS menu not showing correctly!
When I restart to access the BIOS Menu, I press F10. This is the correct BIOS menu button for my model (Desktop 5686). I know this because I have used the BIOS menu before. Anyway, When it comes up it says setup password, and shows a picture of a key. The only buttons that work are the two enter buttons.
  • 68 Answers
Try removing the CMOS battery, waiting 10-30 seconds, and reinserting it. If the computer displays a "CMOS Checksum Error", the password will be cleared, but the BIOS settings will be lost.
Posted on May 18, 2009
Reset bios hp pavilion m7750n
  1. Turn on or restart the computer.
  2. While the display is blank, press the f10 key to enter the BIOS settings menu.
  3. Press the f9 key to reset the BIOS to the default settings.
  4. Press the f10 key to save the changes and exit the BIOS settings menu.
Feb 22, 2017 | HP Computers & Internet
Will not boot. can not access safe mode. can not enter bios
Does it make any noises? Does the display have any writing on it? What is happening? If you decide that you can't answer these questions, just throw the computer away and buy a new one.
Sep 23, 2013 | Dell Dimension 9200 PC Desktop
Advanced boot options
Lenovo Basic Input/Output System (BIOS) settings allow you to quickly customize interactions between your operating system and your hardware, especially your hard drive or drives, memory and power supply.
You must get into the Lenovo BIOS before your operating system loads.
Though most users don't typically see options for entering or using the BIOS, multiple changes can be made to customize and optimize your system, such as changing your boot device order and changing the display brightness to conserve power.
Turn off your Lenovo computer.
Press the power button to start your system.
For best results, wait 30 seconds to one minute before starting your system.
This gives you a longer window in which to enter the BIOS.
Press "F1" as soon as the Thinkpad logo appears.
Depending on your Thinkpad model, you may be prompted to press either the blue "Access IBM" or the blue "ThinkAdvantage" button instead of "F1 or F2."
If this is the case, a message will appear stating "To interrupt normal startup, press (one of the listed buttons above)."
Select the "Start setup utility" to open the BIOS setup menu.
Follow the instructions provided in the BIOS setup menu to select BIOS menu sections, settings and to change options.
Next, navigate through the Bios setup pages using keybard arrow keys in order to find failsafe or optimized defaults press ENTER to select your option press F10 save to cmos and restart
http://www.michaelstevenstech.com/lenovoBIOS.html
Jul 07, 2013 | Lenovo IdeaCentre A600 (3011CKU) 21.5 in....
Disable intergerated video card to allow for pci card to function
You need to access the BIOS to disable the on-board video. Do you have Windows 7 installed or have you upgraded to Windows 8?
For Windows 7, turn off the computer and then turn it back on. After pressing your on switch press Delete repeatedly to access the BIOS. (Some computers use Tab or another key, you should see a screen indicating the correct key.) If Windows starts to load, try again. (I usually have to try 3-4 times to press the key at the correct time following the POST.)
For Windows 8, the boot sequence can be too fast to hit the key. Use the Advanced Restart option. Access the Charms menu and choose Settings > General > Advanced Startup. Alternatively, Charms > Settings > Power > press Shift and then select Restart. This should give you a Boot options menu and you'll be able to access the BIOS from that.
On my machine, I need the Advanced BIOS and then the System Agent Configuration. Then I select Initiate Graphics Adapter. Your BIOS may be slightly different. Go through your VGA graphics for disabling the on-board graphics and enabling the correct PCI/PCI-e graphics option.
I hope this helps.
(make sure that your power supply will support the graphics card.)
Mar 17, 2013 | eMachines ET1331G07w (884483025329) PC...
Floppy diskette failure
Restart your computer during the boot process you will see a certain key to press to enter set up (BIOS) press and hold that key usually the
Delete or F2 key right after you switch on your pc. then will see the bios menu. press enter at the first menu and press down arrow until u see "halt on". it supposed to showing "all error". change that to "no error" and press f10 and then ente r
hope this helps
Sep 10, 2012 | HP TouchSmart IQ506 PC Desktop
How can i getthe bios for may acer aspire one series model zg5
Things You'll Need:
  • Acer Aspire laptop
  1. 1
    Click the "Start" button found at the bottom left hand side of your desktop. Select "Turn Off Computer" in the "Start" menu options.
  2. 2
    Click "Restart" in the "Turn Off Computer" dialog box to reboot your computer.
  3. 3
    Watch your computer's reboot display closely. Press "F2" when you see the system keys display at the bottom of the screen, just before the Windows splash screen appears, to access the BIOS panel.
  4. 4
    Make any needed changes in the BIOS and hit the "F10" key to save your changes and exit the BIOS. Your computer will complete the startup process and launch Windows.
Read more: How to Access an Acer Aspire BIOS ' eHow.com http://www.ehow.com/how_5809235_access-acer-aspire-bios.html#ixzz1E2WkwLWf
Feb 15, 2011 | Acer Aspire One PC Notebook
I have a systemax desktop that runs XP. I installed a Seagate 2T external hard drive to store pics, files, etc. When I turn on the systemax, it attempts to boot from the external hard drive and will not...
Pressing f10 during system restart will gain you access to the bios. Using the arrow keys scroll to the boot sequence and hit enter. this should allow you to choose from , and select a primary boot order sequence. Follow the on screen instructions to make the changes. Then hit esc button. be sure to save and exit setup.
Jan 23, 2011 | Systemax (036052) PC Desktop
Would like to know how you access the setup menu or BIOS
I believe that you want to press the F2 button as soon as you turn it on, and keep pressing it until the BIOS setup screen comes up, If F2 doesn't work then try F10
Apr 04, 2010 | Compaq Presario 5304 (120969-004) PC...
I can't use any USB, it needs a registration on my laptop.. but i don't know how.. help pls!
If you can't use any usb device, the usb function is disabled.
  • To enable the usb function you have to access the Bios setup of your Desktop.
  • By pressing Delete button, F2/F11 button or Esc button in order to open the Bios Settings.
  • During power on the button menu will show up (press the key right away before the Windows starts)
  • In Bios setup there are several menu. Check each of them until you found the settings for Usb Functions
  • If the Usb Functions is disable change it to enable
  • Then go to the Save Menu and Save to apply the settings you created. (Sometimes F10 button is use to save the settings)
  • Restart the computer
To check if the Usb Function is working in windows mode open:
Start Menu > Control Panel > System > Hardware tab > click Device Manager.
Under Device Manager
click the ( + ) sign in Universal Seria Bus Controller
You'll see all the Usb devices detected in your computer
Jan 14, 2010 | Computers & Internet
Reboot
Hi satiewe, no not you're CD. You'll need to enter the notebook's bios. How to get into the bios? Right after you press the power on button, start pressing the delete key every two seconds. The bios main menu should load. If pressing the delete key fail to load the bios menu, try again & press the F2 key every two seconds. The main menu will look like this:
1583ec1.jpg Look at the bottom of the menu & there are instructions on how to move about while in the bios. Go to the title, Advanced.
Listed to the right of; [PATA Primary Master : xxxxx] Where xxxxx is the model number of the hard drive, (Ex: ST80325B). Write this number/letter down. Than go to Boot .
Under boot is, Boot Device Priority. The normal order should be;
1st boot device, [floppy]
2nd boot device, [CD-ROM] - model name.
3rd boot device, [Hard disk drive]? The name of the drive was listed at the main menu as, Pata Primary Master (What you wrote down is what must show here). Than save the bios change & exit. The system will restart. If you placed the correct drive in the correct order you're system will start up.
Good Luck!
Mike
Jun 26, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Compaq Presario 5686 (402445-003) PC Desktop Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
