Question about Onkyo TX-SR602 Receiver
Protect Mode on. Want to repair/return to normal
I have an Onkyo TX-SR602 Receiver. I saw a spark shoot out the back of the unit with an accompanying pop. The unit shut off. I turned it back on and the readout on the front of the unit indicated "Protect Mode" What could cause this and how do you fix it. About how much would it cost to fix it?
    Sniper:
  • 137 Answers
Repair shop will charge around $150 to repair.
Posted on Apr 15, 2010
  • 68 Answers
Sounds like your receiver is fried. Your best choice is probably to take it to a repair facility, where they can figure out what component failed, or to buy a new receiver.
Posted on May 18, 2009
I HAVE A TX-SR602 ONKYO AV RECIEVER AND HAVING PROBLEMS WHEN SWITCHING TO DIFFERENT AUDIO SETTINGS (EXCEPT FOR DIRECT) THE SOUNDS ARE STATIC SOUNDING, LOUD AND JUST DOES NOT SOUND GOOD. I WOULD LIKE TO...
Your problem is in your DSP circuit. This what makes your different soround sound options.
Coil L921 which is located on the DSP board may have opened due to in rush current.
Check coil L921, if open, replace it with a new and improved coil.
The Onkyo part# is 231237M022R2.
Jun 06, 2012 | Onkyo TX-SR602 Receiver
Onkyo tx-sr602 no sound output
Check for your + and - 15Volts DC and + and - 7Volts DC. If they are not there, check the Regulators on that line and the resistors on that line.
May 09, 2012 | Onkyo TX-SR602 Receiver
How can I reset Onkyo receiver TX-SR602 without remote control?
press and hold vcr 1 button and then push power button, it will reset
Apr 14, 2010 | Onkyo TX-SR605 Receiver
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
I have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Nov 04, 2009 | Onkyo TX-SR506 Receiver
Onkyo tx-sr602 as soon as i turn receiver on it flashes protect
Does it display any message like "Protect" or something similar? Do you hear a relay click on then off?
Did the amp just not power up one day or did it stop working while you were listening to it? Finally, do you have teenage kids who might have been listening to your receiver and would have "neglected" to tell you that after listening to their music it suddenly stopped working?
It could be an internal fuse but chances are its something that requires a technician to repair (like the output transistors).
Dec 29, 2008 | Onkyo TX-SR602 Receiver
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Sep 02, 2008 | Onkyo TX-DS838 Receiver
Onkyo TX-SR702 keeps going into speaker setup mode
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
Apr 14, 2008 | Onkyo TX-SR602 Receiver
Onkyo TX-SR602 Receiver Logo
446 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
