Question about Saeco Incanto Classic Espresso Machine
Our saeco incanto turned off for no reason-won't come back on.
I descaled our saeco incanto around 10 cups of coffee ago.  The machine's power went out by itself.  The outlet is good, machine will not power back up.
Thank you for your help! Debbie Kirby
  • kirby31090 May 21, 2009
    Thank you for trying!
  • 1,089 Answers
Push on the right upper side of the door and see if the light comes on?
Posted on May 21, 2009
Hi, mine did the same after a long flight,so I reasoned it was condensation shorting out a circuit. If it doesn't dry out by itself, try pointing a hairdryer through the side vents.And, sorry for the four year delay...
Posted on Mar 03, 2013
How it works decalcing, saeco incanto de lux
from the menu select descaling and open the steam knob. The machine is doing descaling.When descaling proces finish fill the water tank with frsh water and rinse from the hot water .When water finish you are ready to drink coffee.
Jul 04, 2014 | Saeco INCANTO DELUXE Espresso Machine
What is a cheap descaling substance for my incanto delux
If you are really strapped for cash then vinegar or citric acid will work but be sure to mix with water. Download sunbeam em6910user manual and read descale section for vinegar mixing ratio. I personally would look for a cheap sachet of kettle descaler powder and follow directions ( just as good as expensive name brand pre-mixes like saeco and delonghi and much much cheaper). Most descaling substances are based around citric acid.
Dec 09, 2010 | Saeco INCANTO DELUXE Espresso Machine
Machine won't prime
Try lifting the water tank, then setting it back in place, and then priming the machine.
Jan 15, 2010 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
Descaling a Saeco InCanto deluxe
Press and hold the descale button(lower right), it will light up.Then you can start the process. The machine will prompt the next step when the solution in the tank is used up. Have a go.
Apr 04, 2009 | Saeco INCANTO DELUXE Espresso Machine
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Jul 19, 2008 | Coffee Makers & Espresso Machines
Saeco incanto deluxe
Try descaling it manually- by adding the descaler into the tank, letting the machine warm up and then open the water spout to fill one cup at a time. wait 15min. in between. Also clean brew group and grinder.
Jun 10, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto -- no coffee coming out
After I posted this I decided to descale the machine again, even though I'd just done it a couple of weeks ago. After descaling and rinsing I tried running water through the brew group by pressing the pre-ground button, then holding down the big cup button. Still no water, but then I turned the little knob on the coffee dispenser counterclockwise, about half a turn. It worked! I rinsed it well, then made a cup of delicious espresso.
Mar 01, 2008 | Saeco Incanto Classic Espresso Machine
Incanto sirius
seems like its the electricboard to the display that is starting to give up
Jan 01, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Classic Espresso Machine Logo
311 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
