Question about OKI B4600 Printer
Oki 231 3f error
Flashing 3f
Impresora oki b6500
oki b6500 code flash error firmware upgrade que puedo hacer
Jan 15, 2014 | OKI B6500 Led Printer
There is a yellow light flashing which i think is stopping my printer from working.it is the symbol furtherst to the right out of the 4 symbols any ideas
The rightmost LED is the Error light. How fast is it flashing?
If the light is flashing 1 long flash every 4 seconds (no other lights flashing), then either the image drum needs to be changed or the toner is low.
If the flash is one blink a second, then you have a paper problem or a cover open.
If you installed the OKI software with the driver, you can use the Printer Status monitor to identify the problem and order the consumables if you have a slow blink error. (Open the printer control panel (Start >Programs > Status monitor) and Maximize the window to see the Printer status.
You can find the manual for the OKI B4100 here: http://my.okidata.com/PP-B4100.nsf?opendatabase . View all manuals on the right. If that link doesn't work, see the support site: http://my.okidata.com/Home.nsf/Welcome?OpenFrameSet and select the B4100 in the Color/Mono Page Printer drop down menu.
I hope this helps.
Feb 14, 2011 | OKI B4100 Laser Printer
My oki microline 520 elite is showing alarm and the Character pitch of 15 is flashing
This is a checksum error. I would suggest replacing the main control board
Dec 09, 2010 | OKI MICROLINE 520 Matrix Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Machine flashing K Toner Sensor Error - how do I
See if this works - switch off at mains, pull black toner part way out, push back in, switch on again.
Jan 25, 2010 | Office Equipment & Supplies
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
Oki 5521 alarm light flashing. No other lights flashing. Nothing in manual.
You have a fatal error, what kind of error is specified by led combination of PRINT QUALITY and CHARACTER PITCH.
Oct 07, 2008 | OKI Office Equipment & Supplies
Error light on my oki c3300 is flashing new ink and everything looks ok
I had a paper jam on my Oki C3300 and after putting back all the cartridges it flashes green revs up and then goes to error. Also where will I find the error code?
Jun 10, 2008 | Office Equipment & Supplies
There is a red light flashing
From the OKI site, I found this information. My problem is a Flash 2 Blink, which is a problem with the cover or minor error, whatever that means. I can't figure out how to fix it. Any suggestions greatly appreciated!
Flash type Ready LED (Green) Manual feed LED (Amber) Error LED (Amber) Meaning Flash 1 -- slow blink X ecblank.gif ecblank.gif The printer is processing data when printing has been suspended. ecblank.gif ecblank.gif ecblank.gif X The image drum required changing or toner is low. Flash 2 -- blink X ecblank.gif ecblank.gif The printer is receiving and processing data during printing or the printer is resetting itself. ecblank.gif ecblank.gif X ecblank.gif The printer is requesting manual paper feed. ecblank.gif ecblank.gif ecblank.gif X There is a printing error, problem with paper or a cover open. ecblank.gif X X X There is a minor error with the printer. Flash 3 -- rapid blink X X X There is a major error with the printer.
Oct 27, 2007 | OKI B4250 Led Printer
OKI B4600 Printer Logo
42 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
