Sharp aquos troubleshooting
Cannot change channels with remote
  • Televison & ... Master
  • 10,291 Answers
Is TV mode selected? Push a button on the remote and watch for a red led to light. Is it for TV or another component?
Posted on Jan 06, 2014
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
Posted on Nov 06, 2009
satavlad
  • 405 Answers
SOURCE: no input selection availiable on sharp aquos lcd tv
You have to come back to EZ SETUP and complete the setup procedure. Press MENU>SETUP>EZ SETUP.
Posted on Dec 29, 2009
SOURCE: I need the 4 digit remote code for a Sharp Aquos
Try 0093 mate.....
Rgds,
Nik..
Posted on Jul 24, 2010
  • 4 Answers
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Posted on Nov 27, 2010
Why am I not able to change channel on Sharp Aquos television?
Try changing channels with the button on the TV to make sure the remote is not bad. Sometimes one or just a few buttons on the remote will quit functioning. It is usually the ones that are used the most. What channel is the TV on? If it is 3 or 4 or one of the aux inputs; it may have been told to stay that way because the channels were changed by a cable box. Go to set up and scan channels into memory. After it has started, do not stop it until it says on the screen that is finished. If you stoop it before it has completed the scan, the TV will keep its original program. (one channel)
Aug 30, 2014 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 32 LCD freezes on air channel
I had the same problem, same channel, same day. It must be a problem with signal strength. With the TV on, I unplugged the coax cable that leads to my antenna (I am not on cable). As soon as I disconnected the antenna, I could change the channel off of 11.1. I plugged the antenna back in and all other channels work. Hope this helps.
Jan 27, 2013 | Sharp Aquos LC-32D42 TV
Sharp Aquos LC-42D62U 42in hdtv lcd How do I get the channels to change faster? It's like a delay compared to my other hdtv
There is a 3-5 second delay between the channels when you change them on these particular tvs and there is no way to change that unfortunately.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37AD5E
Check componets around MCU (crystal and other capacitors)as well as bad solders on the mainboard.
Feb 04, 2010 | Sharp Aquos LC-37AD1E 37 in. LCD...
No input selection availiable on sharp aquos lcd tv
Dec 29, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Nov 02, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Can't change channels expect by inputing numbers
Try to reload the the remote by using the universal remote code for comcast cable.This number should be available in your owners manual or on the Sharp website. You should search the websites frequently asked questions and troubleshooting sections for you model of television to see if someone already has had the problem answered. If all this fails you must contact the customer service for both the remote and television and get help. Hope this helps you with your problem.
Apr 08, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Polaroid Model TDA-03211C
Our tv sharp aquos LC 52 GD^U 52 in. HDTV LCD plays a narrative along with the closed captioning on selected channels, especially channel 2. We cannot get it to turn off and it is annoying to the point of wanting to return the tv. Please help.
Jul 14, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
