Question about Canon PIXMA MX310 All-In-One Printer
Paper feeds crooked, then stops. I can't find the users manual. Do I need to clean the rollers?
    Sniper:
  • 85 Answers
You may need to replace the rollers. if its feeding crooked it sounds like one of the rollers isnt grabbing which means its either worn or possibly a tension setting.
Posted on May 18, 2009
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
Canon MP210 takes paper crooked and spits out crooked or jams. How to fix? Followed manual for cleaning feed roller but to no avail. Thanks
could it be a paper clip fell into the paper feed slot? see if you can shine some light into the slot and use a dentist's angled mirror to examine. sound like debris may be the culprit. disassemble it to the extent that you have ability to. LEARN THAT WAY!
Feb 12, 2015 | Canon PIXMA MP210 Photo All-In-One Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Paper is pulled through crooked printing is not straight. how doyou clean the rollers?
This can be caused by several factors. It could be that there's something(like small foreign objects in the paper feed area) causing the paper to get crooked. It can also be caused by improperly adjusted paper guide or the paper is not in good condition.
Paper Feed Rollers Are Rolling But the Paper Is Not Feeding
How the Accu-feed Paper System Works
Mar 23, 2011 | Lexmark X75 All-In-One InkJet Printer
When I print something it does not print straight on the page. Can you help me figure out what the problem is?
Something is making the page feed crooked. Are the "fences" beside the stack of paper up against it to prevent it moving sideways? Also check that the feed rollers are clean and have good friction. Plain water on a cloth will usually clean them well enough to feed properly - just be sure the rollers are dry before you reinsert paper. Use a cloth, not a paper towel, because paper leaves fuzz behind, making the rollers slick. In more severe cases I sand rollers, then clean them, but you need to be careful not to get sanding debris all over the printer.
Feb 15, 2011 | HP Office Equipment & Supplies
The print on the paper is coming out crooked sometimes now, like the paper is shifting to one side and getting printed on. I suspect the rollers need cleaned. What are some good chemicals to clean with...
Try cleaning the paper pick-up mechanism, the wheels and feed rollers and everything in the paper feed path with isopropil alcohol, available at most drug stores. It is also used for cleaning video recorders etc.
Jan 26, 2011 | Xerox Phaser 8560DN Printer
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
Paper ALWAYS feed crooked.
Defective rollers or you have something stuck in a corner...look carefully or try cleaning the rollers with robbing alchool (remouves grease)
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Paper feeds through straight at first then scans crooked at the end
This could be because of unclean rollers. The scanner picks paper neat, but images is crooked. This is because paper is stuck on one side and the other side is contnuing on the other, giving it the skew. There may be something sticky on the roller, possibily a left over cellophane tape. Remove it and clean with Isoporpyl alcohol. Dont use solvents.
S. Mohan, Chennai, India
Oct 15, 2008 | Canon DR-2580C Path-Through Scanner
Canon PIXMA MX310 All-In-One Printer Logo
385 people viewed this question
old marine
old marine
