Question about Harman Kardon AVR 335 Receiver
Blown front channel?
I am the original owner of the receiver and she has been great up until now. She has never been pushed too hard for long periods of time and i have a fan wired in that turns on when the receiver is on so there i haven't cooling problems. I waz watching a movie and noticed the i waz missing sound, did a channel check and discovered that my left channel waz out checked all wiring and all ok. i lost my front left. I haven't herd a pop or anything. Is there a reset or am i screwed.... Thanks Paul
  • Harman Kardon Master
  • 15,633 Answers
Hook one of the other speakers to it to see if the problem is speaker or amp.
Posted on Dec 26, 2013
  • Paul Rose
    Paul Rose Dec 27, 2013
    Ive already tried that. I First checked if one of my connections came lose, and still nothing. I disconected the speaker and reconnected, nothing. I did the same with the amp side, nothing. I pulled the amp side and connected a battery to check for wire/speaker connection, check good reconnected wire to amp, nothing. connected wire to a known working channel, good connected another speaker to amp nothing.
  • Paul Rose
5 Suggested Answers
  • 4 Answers
SOURCE: No audio
I know that a couple of you have had the same problem with the blowing 0.47 ohm resistors. I had responded quite a wile back, but forgot to make any updates. Kostiko is correct about the problem relating to these two 0.47 ohm resistors being blown. In my case on two different Haman Kardon models, this was true, but there could also be another issue. What i have found is even after replacing these resistors, the problem appeared to still be there. What was happening was that right after turning the receiver on, the resistors would blow again. What you need to do is replace the two small ceramic disc style capacitors on the same pcb as the fusible resistors, as they could be shorted as in my case. You could remove these capacitors completely, or replace them with a similar size of the same type, as they are really just there for filtering higher frequency noises from the power supply. You can check them with your multimeter first. They shouldn't shorted even in situe. I forget the size, but they are approximately 100 nano farads. Good luck. I have done this to my AVR135, and it has been running great for about 6 months now.
Posted on Feb 03, 2009
  • 4 Answers
SOURCE: No sound from "Front Right" channel
I had a similar problem and i took mine back to circuit city and they told me it was a blown channel, which made since because i was pushing the receiver very hard when i first bought it.
Posted on Nov 29, 2007
SOURCE: no sound on tv after watching a movie
It was just a loose connection.
Posted on Dec 15, 2008
dunnbiker
  • 8546 Answers
SOURCE: Harman Kardon AVR 340 Receiver Has no sound. It
What is the state of the indicated but inidentified digital source? It's trying to tell you to check IT.
Posted on Sep 11, 2011
Panasonic tv model TC-L55ET5 lost 3 digital channels with last update
Those particular digital channels may have been eliminated. The channel lineup changes periodically.
Nov 20, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
How to repair a blown front right channel of a harman kardon avr 347 receiver
oh, your gonna need a paid repairman to fix that, and then you wont be happy with what it will cost, new reciever time
Mar 06, 2013 | Audio Players & Recorders
Pioneer vsx_D710S whatever can be the input source,the flag " poweroff" apears and switch off the system. Seems to have no time rules, shut down frequency connected with hazard ...... No...
I'm not sure what kind of an answer you are looking for. If you are not qualified to do some soldering rework and ready to spend some money (could be as much as 50$) for parts, you better look for a professional service that in most cases will cost as mush (or more) as your receiver.
If you are still reading then here you are. This is a common symptom of a blown hybrid amplifier IC caused by shorting speaker output while it's powered on. There are two protection circuits for amplifier output, Overload and DC output. In your case, most probably, DC output protection is the one that shuts down amplifier to prevent further damage. Find schematics (service manual). To confirm this, look for amplifier inputs connector, measure DC DET. signal, normally it should be around +4.85V. If right after power up it goes down to almost 0V, then it is for sure a blown output on a Hybrid IC. Check whether receiver shuts down with that cable unplugged. If not than get ready to do some rework.
There are two big Hybrid amplifier ICs, one that outputs two channels (usually front left and front right) and 3 channels (for the rest). One of the outputs (if not more) one one of them (if not both) is blown. In most of the 5.1 Pioneer receivers 2 channel IC is PAC010A and 3 channel one is PAC011A. If you want to get original parts and will find those for less then 40$ each you are lucky. There are however cheaper replacements from SANYO, those you can find for around 10-15$.
Find schematics, unsolder resistors one by one that connect AMP outputs to DC detection circuit on each IC and check which one is blown. There are 2 for 2 channel one and 3 for the other. Usually if one output is blown all others on the same IC are blown.
There could be a chance that only one channel on IC is blown, if you want to fix it you still need to replace whole IC. Also, instead of spending on new IC you may want to sacrifice one working channel (center for example) to output the blown one (so you'll get 4.1 :) ).
Nov 11, 2010 | Pioneer VSX-D710S Receiver
Hi One of my surround channels drops out?
Hello
If it is only one channel which is dead, you might just be in luck.
If the amp is still in the warranty period, just send it in, if you open it up, you will loose your warranty.
If it is out of the warranty period open up the amp. You should see the circuit board now and it should look something like this.e1de0ce.jpg
Okay, now follow the path on the circuit board on the channel which is not working. On the path you should see the capacitors looking like this.
Now, it s usually a loose or blown capacitor, you should be able to see very clearly if the capacitor on that certain channel is blown. If you can solder a new one in, if you dont know how, just send it in for repairs, wont cost a lot.
If it is a loose capacitor you should be able to feel it, just have a look, if there is something blown you will notice it quickly. You should also be able to smell a sharp smell.
Kind regards
Andrea
Nov 13, 2009 | Marantz SR-6300 Receiver
Need to reprogram remote for navigo 401. It was dropped into water. took apart, blew out with air, cleaned with isopropyl alchol, reassembled, replaced batteries. light up with all functions, but does not...
I DID SOME MORE RESEARCH ON LINE AND FOUND THAT I NEEDED TO RESET THE RECEIVER CHANNEL FIRST BY PUSHING THE UP/DOWN BUTTONS ON THE FRONT OF THE NAVIGO 401 RECEIVER. tHEN PUSHED THE "SAT" BUTTON ON THE REMOTE UNTIL ALL FOUR BUTTONS FLASHED ON AND OFF.. WITH THE RECEIVER ON, THEN I PUSHED THE CODE FOR THE CHANNEL, (EG: 001, 002, 003) PROBLEM SOLVED. THANKS FOR YOU INTERST IN LOOKING FOR A SOLUTION. I HAD TRIED JUST SETTING THE REMOTE TO NO AVAIL, THEN TRIED SETTING THE CHANNEL ON THE RECEIVER FIRST AND IT WORKED.
Jul 17, 2009 | Motorola Televison & Video
My dish remote wont connect to the dish reciever
If you have a single mode receiver, you need to open the panel in front and push system info.
A channel number will appear near the bottom of the list of information... it may be between 1 and 15. Push the record button on your remote control. (the black button with the red dot). If the channel number changed, then your remote and receiver are not on the same channel. Assume your channel was #1. when you first pushed sys info. You need to program your remote to #1. On your remote, push the Sat button until all other top buttons light up. enter the digit 1 and then the # key. Press the record button 4 times. You have to make sure you have the correct color key inserted in the remote control. If you have a dual mode receiver, one remote key will be green, and the second channel remote will have a blue key. Go to the Dish network website tech portal ...Google will help you find it, for complete instructions from the horse's mouth.
May 03, 2009 | DISH Network 311 DTV Receiver
Marantz SR18-no sound
I have worked exclusivly on marantz recievers, for the last seven years, the loud 'pop' you heard, and smoke, was 90% that one of the amplifier channels, on the amp block, has blown, and consiquently the unit stays in protect mode. It will power up, and decode audio, and even show an f.m. stereo on the tuner, but you won't get the 'happy click' of the protection relays, until the channel is repaired. also replace the 5fd memory capacitor on the front micro board behind the front panel. If you have someone repair the channel, make sure that the tech resolders all of the connections on the molex connectors on the amp block. there are 10 of them, five male and five female, The bad solder on these are what caused the problem in the first place.
Nov 29, 2007 | Marantz SR-18EX Receiver
Center and Surround Channels Inop
Even if it were a fuse, a blown fuse is merely a symptom not the solution. From the symptoms you've described the AMPs are the most likely problem. They are mounted to a large aluminum heat sink usually about center of the main board. There are several and they are a task to remove and replace because the entire board has to be removed... However, it's not too costly a repair and for a qualified shop something that can be done in a couple of hours - including testing. If you like the receiver get it fixed. Compared to most digital receivers today it's probably cheaper to fix this one than buy another. And a good repair shop will add years more life to that unit... Hope this helps. Bill
Jun 06, 2007 | Sony STR-DE575 Receiver
Harman Kardon AVR 335 Receiver Logo
65 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
