When you shift a function, you are _______ it.
  • 600 Answers
If you are just moving the function, without changing the shape of it, I would say your are translating it. Transforming the function includes translating it, as well as stretching, compressing, and reflecting it in the x-axis.
Let me know if you have any other questions.
Good luck,
Paul
Posted on Feb 11, 2016
Inverse log function
For the common antilog, use the 10^x function available as the shifted function of the log key. For example, to calculate the common antilog of 2, press SHIFT log 2 =
If you want the natural (base-e) antilog, use e^x available as the shifted function of the ln key.
Aug 05, 2013 | Casio fx-115ES Plus Scientific Calculator
Compute the nth root
The nth-root function is the right-shifted function of the square-root key, second column from the left, fifth row from the top.
In RPL mode, to calculate the third root of eight, press 8 ENTER 3 right-shift [nth-root] and get 2.
In algebraic mode, press right-shift [nth-root] 3 right-shift [,] 8 ENTER and get 2. (The comma is the right-shifted function of the SPC key on the bottom row.)
Oct 01, 2012 | HP 50g Graphic Calculator
Cant find the arc or inverse button
The trigonometric function [SIN],[COS] and [TAN] have inverse functions arc-sine, arc-cosine, and arc-tangent which are also implemented on scientific calculators. To access the inverse trigonometric functions you use the sequences [SHIFT][SIN], [SHIFT][COS] and [SHIFT][TAN]. The functions are marked on the body of the calculator as [SIN^-1], [COS^-1] and [TAN^-1].
When you use these functions, make sure that the angle unit is correctly set (as required by the problem you are solving) because the angle values returned are in the same unit as the one set.
Jan 15, 2011 | Casio FX-115ES Scientific Calculator
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
SIR, I wish to known MS Office 2007 advance functining & sortcuts
Function keysTo do this Press
Get Help or visit Microsoft Office Online. F1
Move text or graphics. F2
Repeat the last action. F4
Choose the Go To command (Home tab). F5
Go to the next pane or frame. F6
Choose the Spelling command (Review tab). F7
Extend a selection. F8
Update the selected fields. F9
Show KeyTips. F10
Go to the next field. F11
Choose the Save As command (Microsoft Office Button ). F12
SHIFT+Function keyTo do this Press
Start context-sensitive Help or reveal formatting. SHIFT+F1
Copy text. SHIFT+F2
Change the case of letters. SHIFT+F3
Repeat a Find or Go To action. SHIFT+F4
Move to the last change. SHIFT+F5
Go to the previous pane or frame (after pressing F6). SHIFT+F6
Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
Shrink a selection. SHIFT+F8
Switch between a field code and its result. SHIFT+F9
Display a shortcut menu. SHIFT+F10
Go to the previous field. SHIFT+F11
Choose the Save command (Microsoft Office Button ). SHIFT+F12
CTRL+Function keyTo do this Press
Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
Cut to the Spike. CTRL+F3
Close the window. CTRL+F4
Go to the next window. CTRL+F6
Insert an empty field. CTRL+F9
Maximize the document window. CTRL+F10
Lock a field. CTRL+F11
Choose the Open command (Microsoft Office Button ). CTRL+F12
CTRL+SHIFT+Function keyTo do this Press
Insert the contents of the Spike. CTRL+SHIFT+F3
Edit a bookmark. CTRL+SHIFT+F5
Go to the previous window. CTRL+SHIFT+F6
Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
Unlink a field. CTRL+SHIFT+F9
Unlock a field. CTRL+SHIFT+F11
Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
ALT+Function keyTo do this Press
Go to the next field. ALT+F1
Create a new Building Block. ALT+F3
Exit Office Word 2007. ALT+F4
Restore the program window size. ALT+F5
Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
Find the next misspelling or grammatical error. ALT+F7
Run a macro. ALT+F8
Switch between all field codes and their results. ALT+F9
Maximize the program window. ALT+F10
Display Microsoft Visual Basic code. ALT+F11
ALT+SHIFT+Function keyTo do this Press
Go to the previous field. ALT+SHIFT+F1
Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
Display the Research task pane. ALT+SHIFT+F7
Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
Display a menu or message for a smart tag. ALT+SHIFT+F10
CTRL+ALT+Function keyTo do this Press
Display Microsoft System Information. CTRL+ALT+F1
Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
Jan 05, 2011 | Microsoft Office Computers & Internet
How to solve for the trigonometric functions in the casio scientific calculator?
Press the relevant function key [SIN],[COS],[TAN] followed by the angle value.
For inverse trigonometric functions [SIN^-1], COS^-1], or [TAN^-1], Press [SHIFT][SIN], [SHIFT][COS], or [SHIFT][TAN].
For other functions
sec(x)=1/cos(x)
csc(x)=1/sin(x)
cot(x)=1/tan(x)
When calculating trigonometric functions one must make sure that the angle unit the calculator is using is the correct one.
Aug 26, 2010 | Casio FX-115ES Scientific Calculator
How can i get the shift of sine, cosine, and tangent in my calculator?
I am not sure what you mean, because your question already shows what you have to do.
To use the functions marked on the body of the calculator you use either the SHIFT key for the ALPHA key.
If a key has next to it (on the body of the calculator) two markings, the one on the left is accessed with SHIFT, and the one on the right with ALPHA. Colors of commands on calculator body are coordinated with the colors of the Shift key and the ALPHA key.
The question I am asking is whether you know what [SHIFT][COS] means. You probably do, but just in case you do not (no reflexion on your abilities)
[SHIFT] [COS] gives access to the arc cosine function, [SHIFT][SIN] the arc sine function, and [SHIFT][TAN] the arctangent.
May 04, 2010 | Casio FX-115ES Scientific Calculator
How to do inverse of tan cos sin
The inverse trigonometric function share each the same physical key with its direct function. The inverse trigonometric functions are accessed with the [SHIFT] key
[SHIFT] [SIN] accesses the arcsine
[SHIFT][COS] accesses the arccosine
Apr 14, 2010 | Casio FX-9750GPlus Calculator
How to use the cosine,tangent etc functions of calculator fx-82ES plus
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
Nov 05, 2009 | Casio Office Equipment & Supplies
Locating the inverse key for trig. functions
hello,
Use [SHIFT] [COS^-1], [SHIFT][SIN^-1] and [SHIFT][TAN^-1] the keys are the same as the direct function, but they are accessed via [SHIFT].
Be carefule with the angle units when handling trigonometric and inverse trigonometric functions
Hope it helps
Dec 07, 2008 | Casio FX-300MS Calculator
1,792 people viewed this question
jasbo
jasbo
