Question about Motorola Walkie Talkie 2-Way Radio
Motorola mt series not connecting to each other
Just got 2 motorola mt350r for Christmas yesterday. Worked fine for 2 hours, now will not connect with each other. All settings are the same on both. What else can be wrong?
    Problem Solver:
  • 11 Answers
Activate the "channel monitor" button on one radio while talking on the other and see if you can hear the voice. Then reverse the procedure: talk on the first one while holding the monitor button on the other one. If both radios work with the monitor button held down but will not work without then the CTCSS or CDCSS squelch codes aren't set to the same tone or digital frequency or code. Consult the manual for more information.
Posted on Dec 27, 2013
eradiostore
  • 1654 Answers
SOURCE: what will i do to connect Motorola T5720 and T5728
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
Posted on Aug 21, 2008
Niraj Limbu
  • 183 Answers
SOURCE: I need a manual for Motorola MT1000
You can find part manual on following link:
http://www.scribd.com/doc/8782854/MT1000-Userguide
for parts details link:
http://www.diversifiedelectronics.com/pdf/mt1000.pdf
Please post back if it makes any changes.
thank you
Posted on Jan 03, 2009
eradiostore
  • 1654 Answers
SOURCE: does the motorola MT 2000 pickup police stations?
The MT2000 can only be programmed by an authorized dealer. To have the police frequencies you would need permission of the police department, unless you were getting only the receive portion, which would make your radio be like a scanner.
Posted on Apr 03, 2009
eradiostore
  • 1654 Answers
SOURCE: motorola xtn series radios
Here is the link you need: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
Posted on Aug 08, 2009
  • 33 Answers
SOURCE: Motorola radio 2 pin to 1 pin adapter?
http://frontpage.erie.net/carol129/fire_fox/Fire_Fox_Compat.htm
Posted on Mar 02, 2010
I need to know how to use my Motorola kebt-650 walkie. Talkies
Kerri
The kebt-650 appears to be a replacement batter for the Motorola Solutions MU and MT Talkabout walkie talkie series.
Contact Motorola Solutions Get Support
Mark
Motorola Mobility Support
Mar 01, 2015 | Motorola Radio Communications
How do you set the volume on a motorola talk about mt 350
Here's a link to the user guide http://shop.giantintl.com/Manuals.asp select your model from the pulldown
Mar 05, 2014 | Motorola MT350R Talkabout MT350 Series...
Motorola instruction manuals
sounds like your channel and ctcss codes do not match up
here is the manual for all MT model radios, take a look through on how to change the codes, its quite easy
http://www.buytwowayradios.com/products/resources/Motorola/MT350R-Owners-Manual-2.pdf
hope this helps
Jan 14, 2014 | Motorola Talkabout MT352TPR Two-Way...
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
No audio from computer to Motorola S805 Headset
I posted this problem a long time ago. I updated to Windows 7 and my headphones immediately worked flawlessly!!
Dec 29, 2008 | Motorola Mobility S805 Wireless Headset
Pairing motorola hs850 headset with nokia 6680
there's some error in your mobile
Feb 25, 2008 | Cell Phones
MOtorola Ming keeps shutting on and off
check the batery of h/s, or contact motorola care center
Oct 14, 2007 | Motorola Mobility MING A1200
Radio Communications Logo
127 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
