Question about Kodak Easyshare C182 12MP Digital Camera
When I turn on my c182 it says set time and date. when I do that next time I turn it on it says the same thing.
It just started doing this. I've tried new batteries that doesn't help.It takes good pictures just the time and date setting won't stay.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
Usually when doing this you have to press 'Done' or something, not just go back to the menu. If you don't the date doesn't stick.
Posted on Dec 28, 2013
  • 297 Answers
SOURCE: everytime I set time and date, camera turns off.
Memory battery present?? (coin type)
Posted on Apr 20, 2009
SOURCE: turn on camera and set date and time shows up
Take your camera apart and put a piece of electrical tape over the center button (ok) on the menu.
Worked just fine for me after that.
Posted on Jul 28, 2009
BillB-SA
  • 2761 Answers
SOURCE: Camera shuts off after hitting the shutter button
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
shockwave727
  • 262 Answers
SOURCE: My wife`s Kodak Easyshare V1253 has to be reset
Regarding the date and time, Actually its normal everytime you removed the battery you need to reset the date its is because the camera doesnt have a internal or built-in battery that can run the internal clock or maintain the date settings.,
Regarding the taking picture that will take time, it is because your using a too high mega pixel of the camera, Higher mega pixel will have a bigger file size and it will take to process the picture. the best thing you can do is to lower the Mega pixel or the picture size make it atleast 5MP or 6MP., I can guarantee to you you will have a great picture outcome and lessen the time of processing picture.
By the way you can lower the mega pixel (picture size)by pressing the menu button of your camera
Posted on Nov 12, 2009
  • 11967 Answers
SOURCE: My V603 instantly shuts off after I turn it on.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 21, 2009
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 28, 2013 | Computers & Internet
Bios Problem
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jul 30, 2012 | Toshiba Satellite A660-ST2N02 Laptop...
Please tell me how to have my C182 print the time and date on the picture..................
Hello and Welcome to FixYa!
To set date and time on pictures.Follow the given instructions:
  • Turned ON the camera
  • Press MENU, Use Left or Right key to select Setup
  • Use Up or Down keys to select Date & Time
  • Use Left or Right key to move between fields and also press Up or Down keys to change values.
  • Now Press OK to accept.
After it time and date will automatically set on the camera and it will be print on your pictures too.
I hope this solution helps you
Thanks and Keep using FixYa
Jul 14, 2011 | Kodak Easyshare C182 12MP Digital Camera
How do I set this camera(c182) to put on the date/time on pictures?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jan 04, 2011 | Kodak Easyshare C182 12MP Digital Camera
Can't figure out how to set date & time on C182
Clikc over image and go to the User Guide...
Hope this helps (remember to rate this).
Dec 13, 2010 | Kodak Easyshare C182 12MP Digital Camera
How can I set date time stamp on pictures........I have set it on camera, however its not stamping??
The camera stores the date and time (and a lot more) with each picture, but it won't deface your pictures by splashing numbers across them. If you want the date and/or time printed with your pictures, please refer to the documentation for whatever program you're using to print them. Depending on the program and the printer, you may have the option of printing the date stamp on the picture, in the margin, or on the back.
Dec 10, 2010 | Kodak Easyshare C182 12MP Digital Camera
How do you get the date to stamp on the photos on a Kodak EasyShare C182? Thank you, Rene
Nov 24, 2010 | Kodak Easyshare C182 12MP Digital Camera
New kodack c182 camera wont print date and time on pictures after puting date and time into camera. can you help.
http://selfservice.kodak.com/service/panels/solution/printSolution.jsp?solutionId=bdl_dcam_0108 &t=solutionTab&ft=searchTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&viewMode=NORMAL&windowType=SAME&highlightInfo=&isRecord=false
One can go to the menu and turn the time stamp feature on or off.
Aug 08, 2010 | Kodak Easyshare C182 12MP Digital Camera
Setting time and date
From the manual:
1. Press the MENU button to open the menu.
2. Turn the SET dial to select [SYSTEM] and press the
SET dial.
3. Turn the SET dial to select [T.ZONE/DST] and press
the SET dial.
4. Turn the SET dial to select the setting option that represents your time zone and press the SET dial. To adjust for daylight saving time, select the time zone with the * next to the area.
5. Turn the SET dial to select [D/TIME SET] and press
the SET dial. The year display starts to flash.
6. Turn the SET dial to select the year, and press the
SET dial.
• The next part of the display starts flashing.
• Set the month, day, hours and minutes in the same way.
7. Press the MENU button to close the menu and to
start the clock.
Jan 15, 2009 | Canon Video Cameras
GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
Nov 29, 2008 | Nike Triax Fly WK0006 009 Watch
Kodak Easyshare C182 12MP Digital Camera Logo
57 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
