Question about KitchenAid KGYS850LT Gas Dryer
Ignitor will light but will not fire the gas.
I have the kitchen aid gas dryer modle #KGYS850JQ1. My ignitor will light but the gas does not kick on to dry the clothing.
  • 67 Answers
Bad gas valve coil
Posted on May 18, 2009
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 22, 2011 | Dryers
The gas valve will not fire, the ignitor glows but no fire from gas valve
replace your ignitor even if it is glow there is current that need to pass in the ignitor wire and if it is not getting to that current it will not kick on the gas valve , even if it is glowing.
if it is more then 4 years it is that :)
Mar 26, 2011 | Dryers
Ignitor
ok what would u like to know about the ignitor? if you do an amp test on the ignitor it should be reading 3-3.3 amps anything less then this and you would replace please message me back with what the problem is with your kitchen aid stove so that we may properly diagnois your unit Thanks again
Rick
Dec 19, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
My kitchen aid gas dryer is not heating up.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing.
www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | KitchenAid Dryers
Oven won't turn on but burners still will, the other day there was a small fire inside of the oven. The oven has not worked since that fire occurred, removed the sparker couldn't get fire started with a...
if you removed the Ignitor the oven will not light it has a safety valve that operates at this same time the ignitor is trying to get hot once it reaches a certain amount of power it will open the valve for the gas.
you may need to replace your ignitor,and or your electronic control board.
Feb 23, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Accessing the igniter on a Kitchenaid Dryer
Normal 0 Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the ignitor attached to the burner. There is a harness you can unplug to test it. If the dryer is not heating at all, before you remove the front panel, you can remove the cap on the front lower panel and start the dryer. Look inside the holw and see if the ignitor glows at all.
If it glows and then shut down before the flame lights, you will need to change the coils on top the gas valve, not the ignitor.
If the ignitor does not glow at all, you will want to test the thermo fuse before the ignitor.
Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. I know this is a lot of info but these are most common problems.
If I can assist you further, please let me know.
Vic
Jun 02, 2009 | KitchenAid KGYS850LT Gas Dryer
Oven will not lite
Replace the oven ignitor. IT probably still gets red but it has to draw enough current to open the gas valve and yours isnt. Replace the ignitor and it should fix you up.
Nov 18, 2008 | KitchenAid KGSI901PBS Gas Kitchen Range
Kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
KitchenAid KGYS850LT Gas Dryer Logo
160 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
