Tv wont turn on, it only makes the click
When I turn the tv on with the remote or button it only makes the click but doesnt turn on.
  • 126 Answers
Well sounds like you have on h.v. or lost of b+ line also would first check for open solder connection or possible bad solder conn. first okay
Posted on May 18, 2009
Cant change video mode back to tv mode
take ya camera phone turn on the camera take the tv remote and point it to the phone camera lens look in the screen if u see the light from remote flashing as u press video/tv button the button is hence the remote is ok if the remote button is faulty on video it wont flash on screen if so press the tv/av on tv and u are good to go if the tv doesnt respond then the tv programmer ic is mulfunctioning and needs replacement, u may check the memory chip on tv too for mulfunctions
Jul 14, 2013 | Samsung PCJ522R 52" Rear Projection...
Vizio VO47L FHDTV10A wont turn on, logo goes from amber to white, tv clicks once and wont turn on. remote will try to turn the tv on. suggestions?
check your inverter board and wires 2 make shure there not arking. then check your six transformers on your inverter with volt meter
Jan 31, 2013 | Televison & Video
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
REMOTE CONTROL DOESNT WORK
Check the remote control for its infrared emission. If it is OK, the infrared sensor inside the TV might be damaged.
For more details, just type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site.
All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
Jun 04, 2012 | Panasonic Televison & Video
Tv wont respond to remote, remote buttons light up but tv doesnt respond
is it the factory remote? if it is check to see if something is blocking the sensor on the tv, clean the sensors, if it is a universal remote alot of new tvs have codes that even some of the new universal remotes dont support. if thats the case you will just have to make do.
Nov 02, 2009 | LG 42LC2D 42 in. LCD HDTV
TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Aug 04, 2009 | Apex Digital PF2025 20" TV
Television
You need to check what micro switch are bad and replace him because for that the remote don´´t work
Aug 25, 2008 | Televison & Video
My Sanyo TV DS20930 wont turn ON at all
try unplugging for the power source for 60 seconds hold in the power for 10 seconds then plug the power cord while you are hold int power button in then release the power button... now try it (turn it on)
Apr 17, 2008 | Sanyo DS20930 20" TV
Need instruction to program the remote RCA 450
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too.. now since I helped you.. check my band out... www.myspace.com/jumpercablenj
Nov 21, 2007 | RCA RCR450 Remote Control
Need codes for the RC450 remote
ok
Nov 13, 2007 | RCA RCR450 Remote Control
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
