Question about Minolta EP1030/1030F CS/PRO Copier
What does ce 04 00 08 mean? I can get no response from my photocopier. It is a Minlota 1030 f. There is a lot of black lines down the paper when it was working so I am wondering if it has run out of ink??? There is still a small amount in the cartridge. The photo copier has just been moved in a moving truck from house to house. Many thanks for any info you may be able to give. Jo
  • Minolta Master
  • 1,294 Answers
Copy counter display or drum life counter.Not appear one mail icon and arrow down?If yes it is a mantenance time,you ll be change IU (imagine unit)or developer ,OPC drum,2 collars,cleaning blade.
Posted on Jul 31, 2009
Canon ir 1024 photocopier photocopy but the paper is blank what can be the problem
if print from computer ok than problem on scanner or both blank problem on high voltage
Jul 20, 2016 | Canon IR1024 COPIER FOR 220 VOLTS
Reset counter
The problem can be solved exactly from the maintenance manual download here:
http://support.ricoh.com/bb_v1oi/pub_e/oi/0001026/0001026506/VG1398504/G1398504.pdf
Sep 23, 2013 | Ricoh Aficio MP 1600 Black and White...
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
Minlota Photocopier Di Alta Di 351 Broblem code CO510 COULD YOU PLEASE ADVISE ME WHAT IS THE PROBLEM WITH MY PHOTO COPIER AND WHAT COULD BE THE SOLUTION
Hello the problem you have with error code c0510 is caused by the fuser unit the best thing to do is to replace the fuser unit also make sure you have the most up to date firmware installed on the machine
Feb 02, 2011 | Konica Minolta Office Equipment & Supplies
When I photocopy I get a black line down the page, I am using a C
check the drum unit maybe the drum or the cleaning blade is the problem
Jan 04, 2010 | Canon PC-950 Black and White Copier
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Photocopies with black lines from top to bottom.
Try check your paper, see whether loaded properly or not.
If yes, probably u need to adjusting your casette
Feb 17, 2009 | Toshiba 1360 Black and White Copier
Minolta 1030
Depends if the lines go across the page as if the paper comes out or if they go down the page. If across then poss drum, transfer, or fuser unit, If down the page could be a short on the charge then poss only drum unit.
Thanks Jason
Aug 16, 2008 | Minolta EP1030/1030F CS/PRO Copier
102 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
