Savv pdv-3040 The audio won't work. The DVD plays fine but can't figure out the audio part. Does the sound work through my car stereo?
2 Suggested Answers
  • 4234 Answers
SOURCE: Dialog track not playing for a 5.1 DVD
Unfortunately without "surround" processing, the center speaker will not work at all. It sounds like there is a problem with the center channel amp which is part of the receiver. This should be a single amp IC attached to the heatsink. There should be a "test" moe that will send white noise to each speaker in sequence. Try that. If that results in no sound to the center, it pretty much concludes that the center amp needs to be repaired. The part cost for this should be around $25.
Dan
Posted on Dec 04, 2008
Disc plays but no sound
The problem can be in the laser pickup assembly all the way to a bad speaker, try headphones to see if audio is present, if yes! the earphone jack, speaker, and audio output chip is the issue, if no sound! it is more than likely the assembly.
Apr 16, 2012 | Polaroid PDV-0701A Portable DVD Player
Panasonic DVD-S31 won't play sound
Did you change the audio cable, "just to rule out" If it won't work on the Tv or stereo, there probably is a audio processor problem, or a issue with the laser pickup assembly, to repair this kind of problem would not justify the cost.
Apr 12, 2012 | Panasonic DVD-S31S DVD Player
I own two SAVV VAC-IR14 wireless headsets that I use with my SAVV video DVD car player. I am no longer able to hear anything through the headsets. I've replaced the batteries but no sound. Any...
Try checking the base-station and the frequency they're tuned to.
If they both all of a sudden didn't work it must be an issue with the player or the base-station.
Hope this helps!
Jul 04, 2011 | Savv VACIR 22 Wireless Headphones
Durabrand pdv 702 won's play all disks. will play recorded and some orginal but not all
If it only fails on home made discs the problem lies in how they were burnt.
Aug 22, 2009 | Durabrand PDV-709
2005 town and country mini van w/ farenheit dvd player
Some dealers installed a modulator for the radio; look under your driver's side dash to see if there is a small on/off toggle switch. If there is, flip it 'on', tune the radio to 89.1 and you should get audio.
If they haven't installed this, no problem. You can buy a modulator from most electronic stores that is used to play MP3 players through the car stereo; instead of an MP3 player, simply plug the cable into the headphone jack of your DVD player.
Aug 06, 2009 | Farenheit MDM-830CM Car DVD Player
No sound but plays the dvd fine
I think this is due to wrong Audio settings.
Try to change audio setting as Stereo/Right or Left/5.1 from the Audio setup of the Menu
Dec 14, 2007 | Emerson SpongeBob SquarePants 3D Sculpted...
Screen B&W only: Same as other poster
Screen works you get a black and white image. The colour stage works you get colour output to TV So my guess is the ribbon connector from motherboard to screen is loose or adrift. Is this something you fell you can fix or 'know a man that can?'
Aug 19, 2007 | Durabrand PDV-705 Portable DVD Player
No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
May 06, 2007 | Blaupunkt DVD-ME2 Car DVD Player
Lost sound on DVD
I have a CH-DVD 300--not sure how different it is from the 200, but I have the same problem. Putting in an audio CD seems to do the trick, and is less hassle than unplugging (which also works for me).
May 20, 2007 | Cyberhome CH-DVD 300 DVD Player
37 people viewed this question
 Grubhead
Grubhead
