Question about Konica Minolta Office Equipment & Supplies
Error code 2307 konika minolta bizhub 600 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,680 Answers
Sir/Mam
Directly below the drum section is assemble called the transfer/separation assy. (Pull out the middle section will see assy with black grids across it under the grids are some very fine wires) the purpose of this unit is twofold. (It houses several very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevents the paper from sticking to the drum during the transfer process. The code you have been getting means either wires might be broken, or has to be cleaned (because of all the toner on it from the drum assy. which needs to be removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process to leak to ground. have a qualified tech look at it.
Posted on Jul 04, 2016
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Bubbabear64
  • 2794 Answers
SOURCE: konika minolta
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Posted on Nov 07, 2008
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
pineworks
  • 4041 Answers
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Feb 23, 2014 | Minolta bizhub 200 All-In-One Printer
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA BIZHUB C200
You will need to replace the thermostat and the best solution is to ask a technician to do that.
Jan 21, 2011 | Konica Minolta bizhub 200 Printer
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
