Question about Fujitsu ScanSnap Office Equipment & Supplies
Fijutsu scansnap s1300 dead
After not using it for a year - this unit is dead. no light, no noise. Ive tried AC and usb power. is there a fuse or a reset of any kind? thx
SOURCE: No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Posted on Oct 12, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Whirlpool GH518XP
Hattiemay
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 30, 2008
  • 81 Answers
SOURCE: no power on my nc6120
You are most likely dealing with a laptop whose power supply has blown/quit working. You are probably going to have to get someone to change out your power supply, or you might just have to buy a new laptop, depending on how old your laptop is, and how much it will cost you to replace the power. Of course, if your laptop is a newer one, then I am sure it will be worth it to get the power supply fixed or replaced. And if it is even so new as to stll have the warranty valid, you can probably get the computer's manufacturer to fix this at no cost. If warranty is still valid, contact them for details. But keep in mind that computer manufacturers also have limits on warranties, and if you spilled something on the screen or inside the laptop, or you are at fault with any other negligence, the tech support people will detect this, and will probably tell you that your warranty is not valid against spills or negligence, thus requesting you to pay for the repair. I hope this helps.
Posted on Sep 08, 2008
Healeyman
  • 1198 Answers
SOURCE: AC Unit made pop noise when plugged in; Now will not turn on
Look in the electrical control area for a capacitor. They are round cylinders with a couple of wires going to them. A bad one will looked swollen and damaged. If it is bad, note how the wires connect and move the wires to the new one one at a time.
Posted on May 04, 2009
  • 4090 Answers
SOURCE: THINKPAD Dead!!
There are no fuses in the thinkpad there are power transistors and i would think that the main transistor has blown. If a USB plug was faulty it is possible it shorted out when you connected the canera and blew the transistor. It could be quite expensive to have this repaired, especially considering you can buy a toshiba L300 for about $400.
Posted on Aug 16, 2009
Testimonial: "excellent advice, incredibley quick responce, and very well explained. THANKS!!"
I have an IMac with a Fujistsu S1300. I upgraded the harddrive and now the scansnap application does not work. I have tried to re install the scansnap but it always gives the same message" General Error...
There might be a software package that you need to install that you can probably get from the Fujistsu main site. You'll need the drivers for the scanner. I think i've located the correct ones here:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
You'll want to download the proper package. The top one should include the S1300, just make sure you're downloading the correct one. Once downloaded, install, and it should properly function.
Dec 13, 2013 | Fujitsu ScanSnap Manager
Would a dead fuse stop my aztek from showing ANY power???
If your battery is bad you will not start it by jumping the battery, the bad battery needs to be checked, battery life is 4 to 5 years.
Aug 28, 2012 | Cars & Trucks
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
My Scan Snap won't scan. The Scan light just blinks and nothing happens.
My Scansnap was being used through a USB powered hub.
This worked....Shutdown EVERYTHING and unplug computer from your powerstrip for 10 seconds (or just turn off your powerstrip for 10 seconds) It resets the BUS power. This solved why almost all of my USB devices stopped working or were behaving badly.
Jun 01, 2010 | Fujitsu ScanSnap Manager
Scansnap 510 on Vista 64 bit system?
Yes, it *IS* possible to run your ScanSnap S510 scanner on a 64-bit Windows operating system (e.g., Vista 64-bit, Server 2008 64-bit, etc.) but you will need to contact Fujitsu customer support (go to Fijutsu's website and look up their telephone number) and ask them to send you the link (along with username/password) to download the 64-bit versions of the ScanSnap Manager software as well as the CardMinder & Organizer software (optional).
FYI, as of March 2009 that is, the 64-bit version of the ScanSnap Manager is 4.2 L14 and the actual file name that you'll be downloading from Fujitsu's website is called "ssWv42x64.exe" (220 MB file).
Again, this software is NOT available from the public portion of Fujitsu's support website due to legal licensing restrictions. Additionally, this is NOT the same thing as some of the "updates" for Vista they have floating around the public technical support portion of their website.
Hope that helps!
Dec 31, 2008 | Fujitsu ScanSnap Manager
Power dead on Satellite M45-S351
If you forgot your password there is no way to get it unless you
take unit apart removed keyboard look for CMOS battery, if there is one on the unit take it out let unit stan d for 60 second, then put it back in, this sometime clear the cmos,, if all fail it may be your system board
Mar 28, 2008 | Computers & Internet
DEAD
Make sure unit is not plugged in. Use a Volt-Ohm Meter, on Ohms setting, and see if you have connection to the fuse holder. Put one meter lead on the BLACK ac wire, test the ac plug with the other lead (both sides) One should read. Do the same with the WHITE ac wire. One should read.If you get readings on both sides then AC Cord is good. Next check the fuse holder for signs of heat or dis-coloration. If found replace fuse holder. Always remember just because a fuse looks good does not mean it is good, and also I have replaced a fuse with a NEW bad fuse. It happens. To be sure test with meter.
Jan 16, 2008 | LG LMV1650ST Microwave Oven
Maytag microwave - mod# mmv5100aaw
CHECK MAGNETRON RELATED CIRCUIT, HIGH VOLTAGE CIRCUIT, CONTROL CIRCUIT,AFTER CHECK MAINS FUSE.
Aug 29, 2007 | Maytag MMV1153A Microwave Oven
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
Open Questions:
55 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
